You need to contact your vendor as these are similar to your car suggesting you need service. For the Cimnbali (especially the super automatics) there is usually a warning given during the day or just at the morning start. It's usually for cleaning the requires the activation of the cleaning cycle which can take from 8 to 12 mins depending on the model. Some units won't allow a brew unless cleaned. there is a maintenance warning at a certain date or # of days passed. Some will lock out the brewer if not performed in a certain time period.
* Call your vendor for service as most of these lock outs must be cleared by a qualified tech. Some need a special key to reset.
Aloha, ukeboy57
The only way to reset the system is to unplug it for 15 minutes, then plug it back in. But if it is saying insufficient fresh air, then I would check your return air duct and make sure that there is not a kink in the link or a block in the line. If you are still having the issue after what I told you, then a relay has gone bad and the return air sensor will need to be replaced
To perform a clean reset, press the launch button and simultaneously pressing the stylus on the reset switch. Then a warning message appears. Press to do clean reset, or press to leave the operation screen. Performing a soft reset will not change the data in the device; while performing a clean reset will delete all data.
lights usaly come on when there is a system fault. check for a broken or chiped wheel speed sensor ring, or a damaged wheel speed sensor. try disconecting the negative battery terminal for a few seconds to reset lights
Well, If you get this message you should reset the cleaning counter. When this message occures, push both arrow buttons below the display at the same time to reset the counter.
