Question about Panasonic Televison & Video
The panasonic crt tv remains into standby mode the remote and buttons are not responding but the remote and buttons are ok,any ideal
Posted by exaud mteleke on
  • ramal thakur
    ramal thakur Sep 15, 2019
    my tv panasonic power prolam heap me boss
  • ramal thakur
    help me sir
    Top Expert:
  • Panasonic Master
  • 76,416 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Posted on Mar 14, 2016
5 Related Answers
Anonymous
  • 168 Answers
SOURCE: Sony Vega Digital TV model KD-28DX50 U
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service technician
Posted on Jan 16, 2007
Anonymous
SOURCE: tv stuck in standby
I believe these Sony TV's have a built in obsolesence and Sony does not care about fixing them. I don't think a 7-year old TV is an "old model". Who can afford to by an expensive TV every 7 years. Shame on Sony.
Posted on May 01, 2007
Anonymous
  • 34 Answers
SOURCE: SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Posted on Nov 10, 2007
Vista Electronics
  • 1694 Answers
SOURCE: When I am trying to turn on the tv by remote or pushing the power buttton it goes to stand by mode
Solder bad connections vertical output IC......requires chassis
to be pulled....................T.
Posted on Dec 06, 2007
praky16
Prakash Ram
  • 744 Answers
SOURCE: Dmtech TV is stuck in stanby mode
The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
Posted on Feb 12, 2009
Tv standby
If your TV is stuck in standby mode, and does not wake up with the remote, either the remote is faulty (did you check the remote batteries?) or the TV is. Inexpensive current TVs do not have manual buttons on the TV, they depend on the remote for everything.
Jul 30, 2014 | Panasonic Televison & Video
My panasonic crt tv stuck on standby mode only
Hi. Replace the batteries in you remote control already ?
Normally, every TV can be switched on using the local "channel up/dwn " buttons. If this does not work, then there is a more serious problem at hand.
Apr 09, 2014 | Panasonic CT-27SC14 27" TV
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
Unlock a panasonic tv
Hello
If you wants your Pansonic tv to be locked out there is ony way I knew.
Put your TV in standby mode and press the Power and Action buttons at the same time, and turn the main power switch or your TVs front panel to Off. The set should reset to Factory Defaults, and reset the V-Chip. Ok
Nov 17, 2010 | Panasonic CT2722H TV
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Hyundai 42" Plasma TV
Try www.hyundai-world.com That is the manufacturers website. Good luck. Ask them if that set can played in the USA without a special power supply.
Nov 19, 2007 | Hyundai HPT-4250 Television
Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Oct 05, 2007 | Televison & Video
Televison & Video Logo
212 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
