Metra Dash Kit for: 2004-2007 Ford Tarus/Mercury S 99-5718 / 995718 Logo
s
steve taylor Posted on Mar 13, 2016
No power to the instrument cluster - Metra Dash Kit for: 2004-2007 Ford Tarus/Mercury S 99-5718 / 995718
Where is fuse for hud in my 1998 pontiac grand prix
The instrument cluster HUD and the instrument cluster HUD dimmer switch are both connected to the instrument panel wiring harness.
The instrument cluster HUD dimmer switch performs the following functions:
• Provides power to the instrument cluster HUD
• Varies the intensity of the display image
• Controls the motor driven mirror
• Varies the height of the display image
The HUD dimmer switch gets power from IP / IGN fuse -10 amp Fuse Block
Right side of the IP, in the IP compartment opening
03 silverado cluster went dead when battery went dead ,put new battery in and sill nothing ,can you help me
Do you own a professional type scan tool ? Would need to see if the instrument cluster can communicate with scan tool . That would be a priority . If the instrument cluster ,for some reason wouldn't be talking,checking power an ground for the cluster . Batteries going dead , changing batteries without a alternative power supply can cause modules to go to sleep permanently ! Battery Disconnect or Replacement Problems I'am not saying that's what happen to your's . 2003 to 2006 GM had cluster problems ! The solder use in the cluster caused silver migration , instrument cluster caused a drain on the battery overnight . Watch these videos !
Chevrolet Truck Battery Dies Overnight Part II
2005 f150 4x4 power windows ,interior lights a/c ,radio gauges are not working fuses are ok and already check for voltage and it has but still not working . It has something else in betwen..?......
Checked voltage where ?
The instrument control module (ICM) controls power to the power window system by activating or deactivating the delayed accessory relay.
Symptom Chart Condition Possible Sources Action
  • All power windows are inoperative
  • Fuse(s).
  • Circuitry.
  • Instrument cluster module (ICM).
  • Accessory delay relay.
  • Driver window control switch.
  • Go To Pinpoint Test A .
Vehicles equipped with remote keyless entry (RKE) have an illuminated entry feature, which enables the instrument cluster module (ICM) to illuminate the interior lamps (and if equipped, the puddle lamps in the exterior mirrors) when an unlock signal is received from the vehicle security module through the UBP network, or when any of the doors are opened. The ICM controls the interior lamps illuminated entry feature by activating the battery saver relay. When active, the illuminated entry feature will be canceled when any of the following conditions are met:
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Defective Instrument Cluster Module REFER to Section 413-01 . B2499 Courtesy Lamp Output Failure Instrument Cluster Module Go To Pinpoint Test A . B2659 Courtesy Switch Fault Instrument Cluster Module Go To Pinpoint Test C . - All Other DTCs Instrument Cluster Module REFER to Section 419-10 . Do you have a professional grade scan tool ? If not your best bet would be to take your vehicle to a qualified repair shop .
1998 chevy cavalier where is the BCM (body control module) located?
You have no idea what your messing with . Theft light on , DTC'S - diagnostic trouble codes stored . Before you start replacing BCM an making matters worse ,do yourself a favor an take it to a qualified repair shop .
The powertrain control module (PCM) communicates with the instrument cluster using serial data over the UART serial data bus, CKT 800. When the instrument cluster determines a Pass Theft condition, the instrument cluster sends a coded password to the PCM. When the instrument cluster receives the correct password, the PCM enables the fuel injection system in order to allow the vehicle to operate normally. The PCM may allow the vehicle to start and stall quickly during a failed theft condition.
The Passlockâ„¢ lock cylinder is a locking cylinder that turns a rotating magnet past a stationary hall effect sensor. The rotating magnet creates a resistance code (R-Code) that the cylinder sends to the instrument cluster. The Passlockâ„¢ lock cylinder interfaces with the instrument cluster through a 3 wire connection. The 3 wires have the following functions:
• Power
• Ground
• Data
The THEFT SYSTEM indicator will not light under any circumstances.
Replace the instrument cluster.
For Chevrolet vehicles, refer to Instrument Cluster Replacement .
For Pontiac vehicles, refer to Instrument Cluster Replacement .
Multiple indicators light continuously.
Test for a loss of serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1021 sets.
The DTC indicates a loss of powertrain control module (PCM) serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1022 sets.
The DTC indicates a loss of SIR serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1023 sets.
The DTC indicates a loss of ABS serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1011 sets.
Refer to DTC B1011 Passlock Cyl Data Shorted This Ign Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1012 sets.
Refer to DTC B1012 Passlock Bad R-code This Ignition Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1013 sets.
Refer to DTC B1013 Passlock Bad Timing This Ignition Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1014 sets.
Refer to DTC B1014 Passlock R-code Unprogrammed in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1015 sets.
Refer to DTC B1015 Passlock Cluster Fail Enabled in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1017 sets.
Refer to DTC B1017 Passlock R-code Learn Failed in Instrument Panel, Gauges and Console.
The indicator flashes and no instrument cluster codes are set.
So , do yourself a favor an have a qualified repair shop check it out .
2helpful
2answers
All gauges quit working. Replaced all stepper motors. Still nothing is working.
Is there power (B+) an ground's for instrument cluster ? When you turn the key to the run position ( not start ) do the gauges do the sweep test ?
Did you perform the Instrument Cluster Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Instrument Cluster
Turn the ignition ON, with the engine OFF.
Observe the instrument cluster.
Does the instrument cluster perform the displays test?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Turn the ignition OFF.
Disconnect the IPC.
Connect a test lamp between the ignition 1 voltage circuit and a good ground.
Does the test lamp illuminate?
Perform Diagnostic System Check - Instrument Cluster , Diagnostic System Check - Driver Information Systems or Diagnostic System Check - Audible Warnings before using the Symptom Tables in order to verify that all of the following are true:
• There are no DTCs set.
• The control modules can communicate via the serial data link.
Review the system operation in order to familiarize yourself with the system functions. Refer to the following:
• Instrument Cluster Description and Operation
• Indicator/Warning Message Description and Operation
• Driver Information Center (DIC) Description and Operation
• Audible Warnings Description and Operation
If you don't know about serial data communication an DTC'S I strongly suggest you take your vehicle to a Chevy dealer or an ASE certified repair shop .
2answers
In my ford freestyle 2005 the dash lights and everything on there as in gauges, miles , odom, turn signals, won't work, all of the lights on the outside work tho please help !
Check all fuses sometimes fuses tie things together that u would not think have anything to do with one another there should be a full fuse box lay out in the owners manual
No pwer at all going to driving light nor the instrument cluster, starter turns but it won't turn on .and on the fuse block some of the fuses have no power running to them .the fuses are still good
Sounds like you have a power drain (small-amperage short) in the wiring going to your instrument cluster. The short has disabled some of your instrument cluster lights, but, since is has high resistance, it has not blown a fuse (since it draws to few amps). Once the current drain has wasted enough amperage, there's not enough left in the battery to start the car.
Phase 1: Interim solution: (1) charge the battery with your battery charger (if you don't have a battery charger, attach the battery with jumper cables to the battery in a running car - its alternator will charge your battery).
(2) pull the fuse(s) to the instrument cluster, thus killing power to the short.
(3) start and use you car without instrument cluster lights until you can move
to phase 2 of your repair. If you're not sure that you've killed power to the short, disconect the battery each time you stop the engine.
Phase 2:
(1) isolate the problem (the short) to one specific fuse, meaning one specific branch circuit in the car.
(2) trace the wiring from the fuse block to the instrument cluster, looking for
burn marks, bare wires (all wires should be insulated), or anything touching
a frame ground. Also look for moisture iintrusion - water can cause these types of high resistance "shorts" - with the symptom that the problem disappears after the water dries up.
(3) correct wiring problem found in step 2, plug in fuse. done
(4) if replacing instrument cluster, use instructions below.
1995-99 Models
See Figure 4
Fig. 4: Common instrument cluster found in 1995-97 "S" series Pick-ups.
(see illustration at end of message)
1. Disconnect the negative battery cable.
2. Remove the sound insulators/trim panels.
3. If necessary for access, unfasten the steering column nuts and if necessary, the bolts at the lower flange, then lower the column for access.
4. Unfasten the instrument cluster bezel screws located at the lower edge of the bezel. If no screws are present, then remove the bezel by pulling it straight out.
5. Unfasten the four screws retaining the instrument cluster to the instrument panel, unplug any necessary cluster electrical connections, then remove the cluster.
To install.
6. Install the cluster to the instrument panel making sure the cluster is firmly seated onto the connector, attach any necessary electrical connections and tighten the cluster fasteners to 17 inch. lbs. (1.9 Nm).
7. Install the instrument cluster panel bezel by snapping it into position, then if equipped, install the screws along the bottom of the bezel.
8. If lowered, re-position the steering column and tighten retaining nuts to 22 ft. lbs. (30 Nm) on 1995 models. On 1996-99 models tighten the nuts to 20 ft. lbs. (27 Nm). If removed, tighten lower flange bolts to 120 inch lbs. (13 Nm).
9. Install the sound insulators/trim panels.
10. Connect the negative battery cable.
Bmw e36 318is 1997 instrument cluster help needed.Went dead while driving....now petrol and temp/guage not working.....What can i check? replacing the tem swicth and termostat
CHECK 5 AMP FUSE TO THE POWER DISTRIBUTION CIRCUIT WHICH SENDS POWER TO THE INSTRUMENT CLUSTER.IF FUSE OKAY.EITHER CLUSTER HAS A LOOSE WIRE OR CLUSTER SHORTED OUT.IF CLUSTER IS FAULTY. THE BMW HAS TO REPLACE THE CLUSTER BECAUSE NEW CLUSTER HAS TO BE CODED TO MATCH THE VECHICLE.
2answers
What controls the tachometer?
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Silverado instrument cluster repair
1helpful
2answers
Where is the fuse location for instrument cluster on my 04 GMC Sierra?
Here you go. Under hood fuse block
Ign. Fuse E
and
ipc/dic
both fuses are 10 amp
I hope this helps. Take care.
Top Metra Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
