Sanyo DP42848 LCD TV Logo
What could make my Sanyo TV turn brite after 5mins
When I turn on my Sanyo tv the picture is perfect then after 5min. The picture turns real brite and stays that way til I turn it off
5 Related Answers
A
Anonymous
  • Posted on Oct 07, 2008
SOURCE: sanyo dp50747 Plasma HD TV
sanyo recommends using the reset button with cable box on, vcr off and press the reset button 2x, then try pressing channel up button if no message appears on the screen. i have not trid it yet... but good luck
Anonymous
  • Posted on Oct 11, 2009
SOURCE: TV blinks and then no picture at all
HOW DO YOU CHANGE A LAMP BULD IN A SONY HDTV. MODEL#KDF-E60A20
dave1645
Dave Naylor
  • 834 Answers
  • Posted on Dec 07, 2009
SOURCE: I have a SANYO DP46848, after i turn on the TV
The ic on the T-con board is failing you could confirm this by spraying circuit cooler on the ic . The T-con board is located in the middle top on the unit has a cable from the mainboard to the t-Con
and two other going from it to the panel
You can try either Shopjimmy.com or TopsElectronics in Haverhill Ma
Anonymous
  • Posted on Dec 15, 2009
SOURCE: I have had my sanyo dp26649 tv since
your site is a joke...make u seem as u can help and then got to subscribe and pay....put that on site beforehand so we don't waste our time with ur garabge
Anonymous
  • 10 Answers
  • Posted on Mar 01, 2011
SOURCE: rquiroz 3-1-2011 hello my Sanyo
Check the power supply could be a simply a capatitor bad .
46" LCD HD TV no picture until 20 min after being
Check the video module see if you can resolder the components, the tv have some loose connection in that video section and in the power supply.good luck.
2helpful
3answers
LG 52" Rear projection TV
Probably something wrong with the lamp. Buy a replacement.
We have an old TVwhose picture cuts out every 5mins or so
Not a picture tube problem. Re tune the the TV by auto search or manual tuning.
Store your favorites later in your way.
Unable to tune in and get picture/chanels
try to reset ur tv to factory setting.....should be in ur instruction booklet...when done try to set to automatic channel search and it should find Chanel for ur area
10helpful
4answers
Sanyo clt1554 has sound no picture.
I have a Sanyo CLT1554 (2 1/2 years old). Has perfect sound but no picture. The picture will come after several times turning it off/on and pressing the Reset button. It is very anoing to do this evey time. PLEASE HELP
2answers
Picture tube
no you have no vertical bad chip ic
Blue scren
on your tv there are three electrodes on ctr R-G-B JUST ONE BLUE
IS ON SATURATION , NORMALLY THE CIRCUIT DRIVE FOR EVER
COLOUR IF FUNCTIONING GIVES A TENSION CORRECT , SURELY THE DRIVE BLUE IS MALFUNING
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
