"SE" error means you have a shorted membrane keypad.
On some models, you can peel off and replace the old keypad.
On others, it's best to replace the control panel frame, which contains a new keypad already.
You didn't mention your full model, but if it;s the same as the category in which you posted (SMH9187ST) here is a specific solution:
The
simplest way to fix this is a simple DIY solution, to replace the
control panel frame assembly, which comes with a new keypad already
attached.
It is part number
DE94-02001C
"assy control panel" and you can order it from
the Pros here
for about $30 plus shipping.
They may not have it in stock, but if you order it, they can have it in a few days.
You can download the service manual from our site
here.
At
our Web site
, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock:
Then move your board to the new panel assembly, but be careful since the display is made of glass.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
