Question about Kenmore Oasis HE 27082 Top Load Washer
I am trying to take the wash drum off which way does the bolt turn and how do I get it to stop spinning
Posted by Jim Montgomery on
Every time my machine spins the bolt on the drum un loosens and the machine stops spinning help please
Purchase Lock tite thread locker. Loosen bolt, apply this stuff on the bolt threads. Then retighten bolt. This bolt should never come loose again. Yes, you can remove the bolt in the future if you have to for some other repair.
May 26, 2014 | Washing Machines
Left screws in the back of new Zanussi washing now it wont spin
It must have broken some plastic off inside or may have jammed the belt mechanism. Check the belt and suspension/mounting.
Jan 16, 2014 | Zanussi Washing Machines
LG Direct Drive drum not spinning
What is the model number of the unit?
Nov 29, 2012 | Washing Machines
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
My Kenmore front loader (model 417.40042990) makes a slapping noise at he start of the spin cycle and the tub is completely out of balance during the spin cycle. I tried the spin cycle with the machine...
open the door and turn the drum by hand push and pull the drum you may find that the bolt holding the drum in place has come loose you need to take off the rear panel to access the nut or bolt eric
Dec 27, 2017 | Kenmore Washing Machines
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Hoover H110m help needed
hello sounds like the drum is stuck probebly the pole is cloged with hair and stuff if you have the skill open the machine and clean all while your at it look for the belt from the motor check her condition - bad? - install a new 1 there is a stretching unit for the belt 1) relese the bolt of this unit and change the belts 2) pull and stretch the new belt and then close the bolt good luck
Mar 20, 2006 | Hoover H120M Front Load Washer / Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
