Kitchen Ranges Logo
A
Anonymous Posted on Mar 12, 2016
Model KERS303BSS 0. What does "Fault Detected" indicate?
2answers
Have a rudd furnace two steady green lights and flow chart say normal fault detected? But cant seem to get answer for what that means?
If your Rheem furnace has two steady green lights and the flow chart indicates that a "normal fault detected", it typically means that the furnace is operating normally and there are no active faults detected. The two green lights indicate that the furnace is receiving power and that the control board is functioning properly.
If you are experiencing issues with your furnace, it is recommended to check for any error codes displayed on the control board or consult with a licensed HVAC technician for further troubleshooting and maintenance.
Model 5765. What does 09-362 fault indicate?
That error signifies that the toner concentration is high.
09-362 fault, enter dC131 location 09-276 TC lockout high. Check that it is set to '0'. If
set at '1' the toner dispense motor will not run
2helpful
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Power light is green than goes red
Hi beinhauert,
The symptoms you've mentioned indicated that the unit turned to standby mode. This is an indication that there's something wrong on the TV. To help us narrow down where the fault came from, please access the built in "Self diagnostic Screen". Follow the steps below.
In standby mode (red light is on), press the button on the remote control in sequence "Display", "5", "Volume (-)", "Power". Self diagnostic screen's displays its log of error. Please let me know the error code with corresponding numerical value "1" means error has been detected, "0" means no error.
Jdvillanueva
Hello my television is a sony KV32HX15U , when I switch it on the picture takes about 10 seconds to display the television then stays on for about 20 minutes then switches off into stand by mode and...
Hi Gareth,
This model no. has a built-in "self diagnostic software" that can be access to narrow down where the fault came from.
How to enter to self diagnostic screen display.
1. Turn on the main power switch of the TV and enter into standby mode.
2. Press the following sequence of buttons on the remote control.
Self diagnostic error menu will be display. It has an error code no. with the corresponding numerical digit "0" means no fault detected or "1" fault has been detected. See sample picture below.
Please let me know the result to assist you further.
My service engine light is on also, could this be from a blown fuse also or is it just a mechanical indicator?
Hi, the light indicates the computer has detected a fault.
Please see my tip at http://www.fixya.com/cars/r5932051-check_engine_light_check. These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
2helpful
Flashing airbag light
yes, go here for more help. There is a file on how to download codes and clear system.
The number of flashes is giving you a lamp fault code, LFC. What is it giving you?
http://autos.groups.yahoo.com/group/villagerquest/
Diagnostic Test Modes Without Scan Tool
Two mode options are available under the diagnostic test modes:
  • user mode.
  • diagnosis mode.
The ignition switch is used to alternate from one mode to another.
Diagnosis Mode
The diagnosis mode will display any fault present in the system. The SRS will not enter diagnosis mode if no malfunction is detected.
User Mode to Diagnosis Mode
NOTE: The SRS will not enter diagnosis mode if no fault is detected in user mode.
  1. Ignition switch to ON.
  1. After the air bag warning indicator lights for seven seconds, set ignition switch to OFF within one second.
  1. Wait more than three seconds.
  1. Repeat steps 1 through 3 three times.
Diagnosis Mode to User Mode — After Repair
  1. Ignition switch to OFF for at least one second.
Diagnosis Mode to User Mode — During Diagnosis
NOTE: If switch from Diagnosis Mode to User Mode is required while diagnosing a fault, carry out the following procedure.
Clearing Lamp Fault Codes
NOTE: Lamp fault codes must be cleared from memory before proving out the system.
NOTE: When a new RCM is installed, the air bag warning indicator will operate in user mode. Switching to diagnosis mode is not required.
To clear lamp fault codes after a repair, carry out the procedure to switch from diagnosis mode to user mode. Once in the user mode, the lamp fault codes will be cleared from memory.
Lamp Fault Codes
If the air bag diagnostic monitor detects a current fault, the fault code will be displayed with a flashing sequence of the air bag indicator. The fault code consists of:
  • A start signal to indicate the beginning of a fault code.
  • A number of flashes indicating the particular code that has been set.
The start signal:
  • begins with two seconds off.
  • two seconds on.
  • off.
  • one second on.
  • two seconds off.
Following the start signal, if any current fault is detected, the fault code will be displayed. The fault code:
  • is a series of half second flashes of the air bag indicator.
  • is followed by the start signal.
The start signal and the code for any current fault will repeat until the ignition is switched off or the air bag diagnostic monitor is switched to the user mode.
Inspection and Verification
  1. Verify the customer concern by checking the air bag indicator in the instrument cluster. Refer to Prove Out in this section.
  1. Visually inspect for obvious signs of mechanical and electrical damage using the following chart.
Visual Inspection Chart Mechanical Electrical
  • Damaged air bag diagnostic monitor bracket
  • Open fuse
  • Damaged wiring harness
  • Loose or corroded connectors
  • Circuitry open or shorted
  • Damaged shorting bars
  1. If the concern is not visually evident, enter the system Diagnosis Mode.
  1. If no DTCs are displayed in the Diagnosis Mode, proceed to the Symptom Chart in this section.
  1. If DTCs are retrieved, proceed to the Air Bag Diagnostic Monitor Fault Code Table in this section.
Air Bag Diagnostic Monitor Fault Code Table Code Component/Fault Description 0 Normal Operation/No Fault Detected 1 Front Passenger Safety Belt Pretensioner 2 Driver Air Bag Module Circuit Is Faulted 3 Front Driver Safety Belt Pretensioner 7 Air Bag Diagnostic Monitor Fault 8 Passenger Air Bag Module Circuit Fault 9 Low Battery Voltage
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
