Question about Vtech V.reader Animated E-book System
Hi, I have the firmware of V reader 1. Thanks,
  • Anonymous Dec 11, 2016
    Could you send me the firmware by email? Thanks,
    Could you send me the firmware please? Thanks.
How to unlock
Depending on the firmware revision you may be able to reset the password through Google Authentication so first your tablet must:
1. Have been registered with a Google Account
2. Be connected to the internet
3. Have the latest version of Cruz Reader Firmware
If the above is try, try the following to reset the pattern:
1. Try to unlock the pattern 3 to 5 times until you see "Forgot Pattern" pop-up
2. Click on the "Forgot Pattern link
3. Follow the steps to reset the pattern
1helpful
My reader is frozen with the message Firmware update did not complete successfully. Please try again. Will not reset, will not shut off. Now what do I do?
Hi vicky1925!
There is no firmware update for PRS300, I checked on their website www.esupport.sony.com. Maybe sometinhg got corrupted on the internal memory. You can try to do a "Hard Reset" on the eReader. This will set the unit to factory settings and will delete all content:
1. Disconnect the Reader
2. Hit the Reset button at the bottom of the Reader
3. While the reader shows 'Opening Book...' press and hold the number '0' (Zero) and the 'Down Arrow' both at the same time until reset all appears
4. Once you do that you will get a confirmation saying that all content will be removed icon_e_sad.gif you just press number 5 to confirm
If this does not work, contact Sony for service options =(
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
2helpful
Hi, my reader is saying "android.process.acore has stopped" Force closing won't work. I know firmware update via zip file is available but it's midnight here and I don't have an sd card handy....
Sorry to hear your are having issues with your Cruz Reader. I have a Cruz Reader R101. Unfortunately you have to update via the SD card for the Cruz Reader. It doesn't do a firmware update from the USB cable.
If you don't want to try and update it now you could also try to just restart it. If you can't get it to restart normally you can remove the back cover and unplug the battery, then plug it back in.
D_5300 software i have lost the cd
1. Follow this link for the Dynex drivers: http://www.dynexproducts.com/products/computers/DX-CRMN1.html Although this page is for the Dynex 6-in-1 USB 2.0 Mini Memory Card Reader, it should work for your 5-in-1 Reader. Post back here if it doesn't.
2. Click on Windows or Mac under Drivers, Firmware and Software.
3. Download file.
4. Open driver installation package and install driver.
5. Restart computer if necessary.
Thanks for using FixYa.
2answers
HpdeskjetF2480usermanual
You can download and print the instruction manual in PDF format from HP website by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
2helpful
My 8:1 media card reader is incompatible with the SDHC memory in my new camera. I need to upgrade the reader or possibly find a firmware upgrade. I do not know the maker of the internal device and I would...
This will do the job: Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0pt 5.4pt 0pt 5.4pt; mso-para-margin:0pt; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Rosewill RCR-IC002 74-in-1 3.5" Internal Card Reader. I think it costs around $15.
1helpful
System error 0e01 ..
1. Take out the SD card if you have one in the camera.
2. Remove the batteries and leave them out for 24 hours. Put in GOOD batteries and DO NOT PUT THE SD CARD BACK IN THE CAMERA.
3. Power up the camera. See what happens.
if that doesnt help.......
I would suggest to reflash Your cams firmware if it is possible.
1. Download the firmware and extract the .bin file;
2. Copy it to SD card root folder (with SD reader I guess as Your cam is non-responsive);
3. Hold down Menu and switch cam on and proceed...
Best and hope this may be of some help
installing the firmware did the trick for many people....
if it still doesnt solve ur problem afyer u ve installed the firmware.... its time to call casio....
have a nice day and good luck
Hi,I have just purchased a olympus 570 uz and it finds trouble focusing especially on landscapes,also have 2gb card which computer and card tell me to format as it cannot read, could you please...
focus issue... the camera tends to focus in the middle... try changing the scene mode to see if it gets any better
memory card... check to see if your card reader firmware can be updated... older card readers cannot not read 1 or 2 gb cards
NOKIA BARCODE READER
HI, I HAD THE SAME PROB WITH MY NOKIA N95 1 GB, I DID A FIRMWARE UPDATE. http://www.nokia.com/ INSTALL THE (NokiaSoftwareUpdater), RUN THE NokiaSoftwareUpdater FROM YOUR NOKIA PC SUITE. NB!!!!!! REMOVE MEMORY CARD, BACKUP ALL UR DATA THAT YOU DONT WANT TO LOOSE!!!!! RUN BARCODE READER, LINE THE CODE UP, BETWEEN THE 2 RED LINES, AND WHALA!!!!
SDHC High Spedd Card Reader in PowerShort SD500
Sorry, no. SDHC cards are electronically different than SD cards and will not work in devices not originally designed to accept them. This is a hardware difference and cannot be changed by firmware.
Vtech V.reader Animated E-book System Logo
Top Vtech Toys Experts
tina gallow
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Vtech Toy Expert? Answer questions, earn points and help others
