Question about Samsung Televison & Video
My tv won't turn on. It starts to turn on then shuts off on it's own. The timer is clicking on and off,which in turn,turns the tv on/off repeatedly.
It want's to turn on,but only makes the begining sound of turning on, then turns on/off repeatedly.
    Top Expert:
  • Samsung Master
  • 12,962 Answers
U have a sick puppy there. I would check out the power supply for bad parts.
Posted on Mar 11, 2016
5 Suggested Answers
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: my tv keeps clicking and won,t turn on
It is very possible that the power supply may have gone out. Which unfortunately is common on many newer tv's and other appliances. You can use a multi-tester or voltage tester to see if there is any power coming out of the power supply.
Posted on Jun 15, 2009
Clefton Badecao
  • 100 Answers
SOURCE: Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Posted on Aug 07, 2009
electroman
  • 1039 Answers
SOURCE: turn on tv and purple pixels like snow are spread around tv.
First thing replace any swollen capacitors in the power board.
Posted on Sep 01, 2009
Jack South
  • 195 Answers
SOURCE: my tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Posted on Oct 12, 2009
Kaufman605
  • 608 Answers
SOURCE: The TV isnt turning on, its only making a clicking
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 19, 2010
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
My lights on my 1996 caravan won't shut off until the timer shuts them off and they turn on when any door is opened
You are talking about interior lights, right ?
As long as the on-time is under a minute or two, its normal.
The lights are supposed to go off as soon as you start the van tho.
Jul 02, 2012 | 1996 Dodge Caravan
Whirlpool LER5636PQ1 DRYER starts when I hold the button then shuts off
Your motor has gone bad. Think of the motor as a starter in a car. When you turn the key (press the start button) power is applied to the starter, to be specific, the stator also called the start winding, same as the dryer. Then the rotor takes over and the stator drops off. With your machine the rotor isn't engaging and the stator is taking the load and shutting down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Whirlpool Dryers
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
TV acts like it is turning on then shuts off then repeat, repeat
When my lamp died the bulb literally exploded. That may be what you heard. Have you check the lamp? If the lamp is ok, the lamp's ballast or power supply might have blown.
May 22, 2009 | Toshiba 62HM95 62" DLP HDTV
Philips 43PP8421 turns on and off
check to make sure that you dont have any timer set, it seems that you just have the timer set to 15mins and it keeps repeating just simply turn off the timer if this is the case.
Apr 21, 2009 | Philips 43PP9202 43" Rear Projection...
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
Televison & Video Logo
186 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
