Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
SOURCE: hp laserjet 1200 paper jam
Please Follow the instructions in an attempt to resolve the issue you are facing:
Still getting the same error ? Go for Warranty or Service.
Else,
If you still get the error let me know for further troubleshooting,
Dont vote till you find it is Helpful or FixYa.
Thanks,
Scott
SOURCE: 49. 2F05 SERVICE ERROR
It is probably both the fuser and the firmware.
Power Off/On and see if the firmware issue goes away.
From the control panel go to the Diagnostics Menu and select Print Event Log. It will give you a list of errors and what they pertain to, along with the page count when the event occurred.
Open the duplex pan (at the front of the printer, open the paper tray, and push the green button on the right in the tray cavity) and check for any small piece of paper that may be in the path. Verify that the hinge of the pan (where it connects to the printer chassis in the rear below the fuser assembly) is attached and not off its hinge. This can cause duplex jams. Additionally verify that the rear cover is not broken as the printer uses this to turn the paper.
Behind the rear cover is the fuser assembly. It may have a torn fixing film sleeve at one end or it may be contaminated, which can cause your image problem. It covers the ceramic heat element and sits above the lower pressure roller. One way to verify if the problem is the fuser is to print something from the control panel (like the configuration page located in the Information Menu). When the paper is under the cartridge but has not entered the fuser power off the printer. If the image mark is on the page its not the fuser because the paper hasn't gone there yet (try a new cartridge) if it is not on the page then the problem is the fuser.
SOURCE: My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
SOURCE: After turning on printer, prints initial "blank" sheet
You can fix this by turning off bidirectional support:
- Right click your printer, select properties
- go to the ports tab, uncheck Enable bidirectional support.
Your printer has to be turned on before printing.
That fixed the extra page printing S1M problem for me.
Testimonial: "Solution worked great and will save future trees by not wasting paper! Thanks for the help."
