Question about Eclipse Audio Players & Recorders
I formatted my eclipse 28V now not showing any program file how can I restore original setup files
Posted by ryan bacon on
Bill Boyd
    Top Expert:
  • Eclipse Master
  • 53,816 Answers
Sorry , formatting means all files folders and operating systems are deleted permanently
you have to use an installation disc for the operating system , then use any back up files that you have on an external hard drive to replace the deleted files
Posted on Mar 10, 2016
Huge files of page maker 6.5 was kept in local drive F, when i tried to open the said files it does not open and show that this format cannot open with this application.
Try re-creating the preferences of your pagemaker software by following the mentioned steps: (Steps are mentioned considering you have Windows XP installed)
1. Close PageMaker id its running
2. Open the Program Files/Adobe/PageMaker 6.5/Rsrc/Usenglsh folder.
3. Rename thefollowing files (for example, to Pm70old.cnf):
-- Pm70.cnf
-- Pm70filt.cnf
-- Pm70ppd.cnf
-- PStyles.cnf files
4. Start PageMaker. It will re-create preferences files.
If the problem continues, the preferences files is not the cause. To restore custom settings, delete the new preferences files and restore the original names of the previous preferences files.
See if this works and reply back.
Jun 01, 2011 | Computers & Internet
Eclipse cld2 player won't play with headphones, says no files, but when pluged into computer file shows up on laptop and will play through media player? Why can't player find files downloaded on it? ...
This mp3 player is only compatible with mp3 files. If you can play the songs with your media player, chances are that you have the wrong file format for your player. WMA and m4A file formats are not compatible.
To convert your audio files, use the free program found at this location. http://download.cnet.com/Koyote-Free-Mp3-Wma-Converter/3000-2140_4-10442362.html
Remove the incompatible files from your mp3 player.
Import the mp3 files into your media player, then transfer them to your MP3 player.
Mar 07, 2011 | Eclipse CLD2 MP3 Player
My Mcafee antivirus is not working and system has found errors. Also, Internet explorer is not opening. It has showing syntax errors and asking for sending reports. kindly suggest what to do?
This problem actually arises when some of your System Files get corrupted. Getting back your original setup is almost impossible. You have told that your antivirus is not working, so there is a very strong possibility that your system has got corrupted by the virus infection. Firstly, I recommend you to scan your system with a well-established antivirus.....likely AVG Antivirus (if you are using Pirated Windows Copy) or Microsoft Security Essentials (if you are using Original Windows Copy). If this antivirus shows viruses and you are unable to get back your original system files, then go for Windows Update (for Original Windows) and your files be restored. If this one also does not help you, then go for the System Restore option. This can help you to restore your files to a better condition. You can find System Restore in the All Programs>Accessories>System Tools>System Restore option. Let's hope that this will serve you well.
Feb 04, 2011 | Computers & Internet
I am using : windows XP ser.pack 3, Ram:2GB, hard disc cap: 320GB. program using : ULEAD media studio Pro 8, i was editing a bunch off video projects since last 3 days, all working well, but today when...
HI.
If your setup file was from another source and not the original cd it will cause damage.
Backup your Data, all saved data as well.
Go to system restore. START PROGRAMS - ACCESSORIES - SYSTEM TOOLS - SYSTEM RESTORE.
Make sure your anti virus did not put any of the files in quarentine.
After restoring the system, run the program and enjoy.
P.S use original cd
Nov 26, 2010 | Computers & Internet
Problems loading file on RM Easiteach
Errors in your registry are one of the common causes for incorrect file associations on your windows system. It is highly recommended that you check your registry for file association errors (will also check for any other registry errors).
The ETL file type is primarily associated with 'Eclipse' by The Eclipse Foundation. Eclipse is an open source community whose projects are focused on building an open development platform comprised of extensible frameworks, tools and runtimes for building, deploying and managing software across the lifecycle. Your workspace setup may consist of several projects from one or more repositories. Once you have setup your workspace, you can share it with others by exporting a Team Project Set.
Cannot access ETL files on windows? When windows gives you an error message saying that it
"Cannot open ETL files", this means either:
A. You need to identify a program that can open the file
B. Or your registry may be damaged
RECOMMENDED:In both cases it is strongly recommended that you
run a free scan for registry errors.
File extension: .ETL
Detailed information for file extension ETL: Primary association: Eclipse Company: The Eclipse Foundation Other applications associated with file type ETL:
  • ThermaData Logger (Log Data File) by Electronic Temperature Instruments LtdThermaData Logger is a cost effective, self-contained temperature data-logger or blind recording thermometer designed to record the temperature of the surrounding environment. This association is classified as Database.
  • Windows2000 Trace Log(TRACEDMP.EXE from Win2000 Resource Kit to create DUMPFILE.CSV for viewing by other applications) (performance monitoring)
Nov 24, 2009 | InterAct Accessories RM Easiteach...
Crashed desk top been reformatted wontaccept medion system files
Seems like you will need to get your hands on a restore disk or windows installation cd for the version you have.
You will need to either restore the computer to the original state or install a fresh installation of windows from the setup cd, after that you need to get the drivers for the computer from medion support.
http://www.medion.co.uk/service/?drivers_updates/drivers_updates.htm
Jan 21, 2009 | Medion MD-1704 PC Desktop
Windows could not start because the following fio valiant 671dp
Contact the makers of your laptop and order the recover disk. They go around $40.00 to $50.00 dollars.
Dec 28, 2008 | KDS Valiant 671DP Notebook
Mustek pvr-h140
Are you trying to restore the files you previously had on your Mustek or just trying to get it to work as it did before the format? If you're just trying to get it to load, follow these instructions:
"Install the PVR Console software in the bundled CD and connect the device to PC. The software will help to restore system data and boot up files to the device automatically. When the copying is done, restart the device for twice."
If you're trying to restore the data you accidentally formatted, connect it to your PC and try using a program such as Free Undelete to restore the files that were previously deleted. In the program, you need to browse to the drive that your Mustek shows up as on your PC (so if the drive is X: you need to restore files on X in the program).
Jan 09, 2008 | Mustek PVR-H140 Digital Media Player
59 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
john h
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
