Question about Samsung DLP HL-P5663W 56" TV
Problem with my samsung dlp model# HL-R6178W.
Hit the start button tv goes through its start up mode. light blinking but the tv doesn't come on. I hit the power button again and again. bottom line it takes a long time to turn on. I've change the color wheel, lamp, ballast. still the same. help me out please. when it comes on it stays on until you turn it off.
Posted by Gilberto Rivera on
3 Related Answers
Anonymous
  • 58 Answers
SOURCE: Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Posted on Apr 25, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Samsung HL-P6163W DLP TV won't turn on. The lamp
Dmd Module- 1-800-638-3328
Posted on Mar 24, 2010
TODDAS
Todd Hill
  • 433 Answers
SOURCE: samsung dlp hlr6167 no picture or sound when
Check for the 330v ac coming from the power supply to the ballast.
Posted on Nov 11, 2011
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
I have a samsung hl-r6178w, it suddenly turned off & the 3 lights in the front started blinking & it would not turn back on. i replaced the lamp now & still nothing, what can i do?
In regards to your issue, I got a question for you: when your tv2.gif turns on or tries to turn on, do you or can you hear a humming, buzzing or rapid click noise coming out of the tv? if you say yes this could be an issue with the ballast and most likely needs to be replaced as soon as possible the definition of a ballast and how it works is this: A ballast is an electrical component used with a fluorescent bulb (or mercury vapor lamp or arc lamp) to conduct electricity at each end of the tube. It supplies the initial electricity to the bulb that creates light, and then it regulates the amount of electricity flowing through the bulb so that it emits the right amount of light
You can go to DM the have this parts and you can get a good price,http://www.discount-merchant.com/?click=52978
please keep us posted
good luck
Oct 01, 2009 | Samsung HL-S5087W DLP TV
Samsung hl-r6178w 3 blinking lights
The power board ic converter is dead.
U can tries to go to the web buy the part and replace it yourself.Or hire the repair man part and labor $575
Aug 13, 2009 | Samsung HL-S5087W DLP TV
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Where can I find a Samsung repair center?
LG DLP PROJECTION TV (RU-44SZ63D) Tv light is off (with red light on). When I hit the power on button the red tv light starts blinking. Light continues to blink red then stops blinking and goes back to off (red light on).
Jul 12, 2008 | Televison & Video
Samsung remote code for dish net. not working
Try 069, 070.
Pick your Mode, then Hit the set button at the bottom, then type in the numbers and you should see the mode light up 4 times if done correctly. Hit power and see if it goes on. I think the Frequency changed though.
Dec 08, 2007 | Televison & Video
Samsung DLP HL-P5663W 56" TV Logo
148 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
