Uniden cordless phone visual ringer keeps blinking on and off the cradle,triedto pressed and hold the find/key button but it didn't worked,we don't have unread messages/ missed calls,could someone help how tofix it please
That might be the Voice Mail Warning Indicator.
On the D1680 and similar handsets, it is reset by:
1. press [menu]
2. scroll down to "Global Setup", press [select]
3. scroll down to "VMWI Reset", press [select]
4. scroll down from "No" to "Yes", press [select]
5. handset will chirp, blinking lamp goes out,
6. press [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
SOURCE: Uniden Ex18560 series cordless phone
when I have voice mail messages un-checked, it blinks steady. after erasing, it works right
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: Continuous Flash of Visual Ringer(Uniden DECT 6.0 Cordless)
UNIDEN MODEL EZX290 HANDSET>>>VISUAL RINGET AT TOP (YELLOW LED) FLASHES. HOW DO I TURN THT OFF?
SOURCE: one handset gives the message, blinking, Welcome!
I replaced the battery. It solved the problem.
SOURCE: the visual ringer keeps flashing on my uniden cordless phone
I CALLED UNIDEN WITH THE SAME PROBLEM.
THE VISUAL RINGER IS FLASHING WHEN YOU HAVE OLD EMAILS. YOU HAVE TO DELETE THE OLD EMAILS
