Question about Zebco 33 Bite Alert Spincast Reel
How do I my repair my fishing reel
The alarm will sound when turned on but will not set off alarm when line is pulled
Posted by Gary s on
bongani doctor mthembu
    New Friend:
  • 16 Answers
New roller put it in a stick and ties on your fishing rod then roll until It finish
Posted on Jul 15, 2017
Steve P
  • 3,712 Answers
What causes the fishing reel to skip teeth when retrieving line?
I went fishing with a commercial fisherman. I had a freshwater spinning reel and we were fishing for mackerel and Pollack. He told me pulling fish upwards from the bottom would damage the teeth on the retrieve because a spinning reel is designed to pull fish towards you at an angle, whereas in boat fishing you are hauling from below. After bringing up 3 lots of line with 4 to 6 mackerel on feathers, the teeth started to skip. He said "I did tell you". I wasn't too worried as it was a very cheap reel. The next week I bought a Penn 10 which was what he recommended.
Basically you have stripped the ends of the teeth. Depending on the quality of the reel, you may be able to get spares, or otherwise you upgrade.
Mar 31, 2016 | Fishing
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
SHIMANO FISHING REEL
The drag is set by turning the knob which secures the spool to the reel.
To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
The bail is the wire-like device on the top of the reel.
There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
I think those are the highlights.
Charlie
Sep 10, 2009 | Shimano REELS TYR20 Tyrnos Lever Drag...
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
Orvis wood reel battery clock
Apr 05, 2017 | Home
Zebco 33 Bite Alert Spincast Reel Logo
729 people viewed this question
Top Zebco Fishing Experts
Thomas Perkins
Thomas Perkins
ray gallant
Arthur
Are you a Zebco Fishing Expert? Answer questions, earn points and help others
