Question about Zebco 33 Bite Alert Spincast Reel
Alam will sound when turned on but will not activate when line is pulled
Posted by Gary s on
My alam is not sounding when I lock and unlock my car can the alam be reset
depending on what car it is, if the locking/unlocking is working, it sounds like you have it on deadlock.
check your manual how to re-set.
Apr 29, 2016 | Cars & Trucks
How to unlock sony dvp- sr320
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Aug 10, 2015 | Sony Televison & Video
Why doesnt my audible alam sound when the alarm is trigged.
For starters first check the wire going to the horn, it may be cut.
Jul 10, 2014 | 2002 BMW 3 Series
Paano ko maa activate ung gprs ng cherry mobile cellphone unit ko
Hello Annalyndael,
You can do that by calling your mobile service provider and request them to activate it for you. Iba iba kase ang settings bawat phone and bawat service provider. Halimbawa sa Globe, iba ang settings sa Smart and iba din sa SUN. Kaya kapag ni setup mo yang phone mo for Globe GPRS, kapag nilagyan mo ng SMART na simcard, hindi din gagana ang GPRS.
So, tawag ka po sa globe/smart/sun or kung ano mang simcard ang gagamitin mo, tapos sabihin mo na ipapa activate mo yung GPRS ng phone mo. Dapat alam mo din yung model number ng cherry mobile phone mo para mas madali nilang ma-activate.
Pakirate naman yung sagot ko.
Thanks for using Fixya!
-damneddle
Oct 06, 2011 | Cell Phones
95 sentra will not start alam does not turn off
IF YOU CAN GET INTO YOUR TRUNK, YOU WANT TO PULL THE WIRE OFF FROM BEHIND THE LATCH FOR THE TRUNK LID, AFTER DOING THAT TAKE A MAGNET AND WAVE IT ACROSS THE METAL AREA WHERE THAT WIRE WAS YOU TOOK OFF. I HAD A LOCKSMITH DO SOME WORK ON MY MAXIMA THIS YEAR AND HE SHOWED ME THAT TRICK. RESET THE ALARM AND SHUT FLASHING AND HORN OFF. NEAT TRICK. SHHH
Jul 23, 2011 | Bypass Essentials xk02 Doorlock Alarm...
Binili ko s USA ng dinala ko s pinas...naka problems kaya pina reformat ko. then ganon p din problema p din. pinatingnan ko s friend ko.don di ko n alam ginawa nya i think may pinalitan sya n d ko alam...
PAG WALA SOUND NEED MO PO NG MOTHER BOARD INSTALLER...NGHAHANG P DN PO MINS MY VIRUS P OR ELSE PNLITAN PO TLG HARD DISK NIAN..EH ANG PNLIT EH D COMPTIBLE S PC NIO
May 14, 2011 | Computers & Internet
1998 Catera, the alarm system started to sound and I don't know how to reset it, or what set it off. We had the car sitting out all day, waxed it, left the windows down, and when we opened the door the...
there is no reset, whenever you turn the igntion key to on or unlock the door with the remote or the key the system is disramed, if it goes off like you have going on a sensor in the system is defective and you will need the dealer to scan the system for the fault.
Sep 30, 2010 | 1998 Cadillac Catera
Key fob has stopped working wont turn off alam,immobiliser.
lock the car with the key and hold opver for 30 secs then press/hold unlock button on key fob for 30 secs,should reset....
Mar 21, 2010 | 1995 Saab 900
Audio File not available on Server
hallow thre ,looking for sound drivers ,try this websites http://www.softwarepatch.com/utilities/ac97.html
if this doesnt work try this
http://www.softwarepatch.com/utilities/viaac97.html
Jan 11, 2009 | Mercury P4VM800M7 Motherboard
Ok...next...
Good Day, egear00;
Try looking at this, since you sound like a TECH;
The Fan alarm is activated when the Fan does not run. This can happen in two different circumstances.
  1. When the Fan Fails due to a malfunction.
  2. When the Power is turned off. The FAN +12 regulators turn off and the fans quit.
(1) When the Fan Fails:
In this situation the fan alarm will be activated. Inside each fan is a hall element that keeps pin 1 of the connector pulled low when the fan rotates. If the fan stops, the pull up resistor connected back to the Fan 12+ pulls the alarm line high. This high is routed through two Diodes to the shutdown circuit of Q905, Q906. When the base of Q905 goes high, it's collector pulls the Power 1 (Power On) command line low which shuts off the relay driver Q903. The purpose of Q906 is to make the shutdown circuit appear like an SCR. If there's any pull up voltage being supplied, (in this case from the Power 1 line), the emitter to collector current of Q906 will keep Q905 in the On condition. This circuit will remain latched as long as the Power 1 line remain in the on condition.
An additional route for the Fan Alarm is out the PPS2 connector pin 9 to Q562. The Fan Alarm high will cause Q562 to turn on and pull the Fan Alarm pin 48 of the Microprocessor low. When pin 48 goes low, the Microprocessor will in turn activate the Temp LED and cause it to Blink. (See the Temp Alarm Circuit for more details).
(2) When the Power is turned off.
When the Power is turned off, the Fans do not run because the Fan +12V regulators I906 and I907 are turned off. This would generate a false Fan Alarm, so the Microprocessor outputs a High from pin 56 to Pin 7 of the PPS2 connector. This high turn on the Fan Alarm Enable transistor Q908. When Q908 is turned on, the collector is held low to prevent a Fan Alarm. This low keeps D916 and D918 cathodes held low.
click-to-view.gif Click to view Larger Image separately.
fan-alarm-protect-sm.jpg Good Luck, big IRISH.
Aug 20, 2008 | Hitachi 60V500 60" Rear Projection...
Zebco 33 Bite Alert Spincast Reel Logo
291 people viewed this question
Top Zebco Fishing Experts
Thomas Perkins
Thomas Perkins
ray gallant
Arthur
Are you a Zebco Fishing Expert? Answer questions, earn points and help others
