Question about Vehicle Parts & Accessories
Ok i'll try it again 2.0 4 cyl. tucson timing belt points hyundai 4 cyl
No more details are nessery
Posted by dingi Dingi on
My hyundai tucson is making quite a loud rattling sound at low revs but disappears around 2500 revs. it's worse in high gears
It may be worth looking at the timing belt tensioner pulley bolt to see if it hasn't worked loose, the belt may be about 3/4" of slack, which could cause the belt to slap against the inside of the cover at low rpms. It can also slowly shave away the backing of the belt. There could be about half a cup of timing belt dust/shavings collected in the bottom of the lower timing belt cover.
Sep 14, 2014 | 2005 Hyundai Tucson
Watrpump replacment
the water pump is located on the side of the engine block where the cam belt is .its a straightforward job but again its a physically hard job as the cam belt and auxiliary belt need to be removed .and you will loose all your coolant .then the timing will need to be set up .when your car is due for a cam belt { its always worth replacing the water pump on any car }as its such a pain trying to change the pump again ..if you are thinking of doing this yourself ..I would think again ..it is beyond the scope of a DIY mechanic from the point of view you will nned a ramp and even if you a good home mechanic I doubt that you will have a 2 post ramp!
Sep 04, 2013 | 2006 Hyundai Tucson
Timing belt broke 2005 hyundai tucson. New belt & tensioner& water pump Compression check shows no compression # 2 & # 6. Is it worth it to rebuild top end ?
I would say so, most probably the valves have been bent by hitting the pistons when the belt broke. When the belt breaks, the valves stop mmoving, and the pistons keep moving and will hit the valves and damage them.
Mar 21, 2013 | 2005 Hyundai Tucson
How many bolts on the thermostat housing? 2005 hyundai Tucson 2.0 4 cyl
should just be two bolts, one on each end of the housing
Oct 08, 2009 | 2005 Hyundai Tucson
I need instructions on replacing the timing belt
1. Remove the Alternator Belt.
2. Remove the Water Pump Pulley
3. Remove the Air Conditioner Belt and Power Steering Belt.
4. Remove the Crankshaft Pulley.
5. Remove the timing belt cover
6. Remove the timing belt tensioner pulley.
7. Remove the Timing Belt.
8. (If Replacing) Remove Idler Pulley.
Installation is reverse of removal. Keep a close eye on the timing marks on the cam sprockets to make sure you don't knock anything out of whack.
I would strongly recommend replacing the water pump while you are replacing the timing belt. (The water pump usually comes in the timing belt kit.) Otherwise you are going to have to do this all over again when your water pump goes out. Good Luck.
Nov 10, 2008 | 2004 Hyundai Tiburon
How often do I have to change the timing belt
On the 2L (4 cylinder) engine it is recommended to inspect the belt at 37200 miles and replace the belt at 56000 miles.
On the 2.7L (V6) it is recommended to replace the belt at 60000 miles.
And, both these engines are interference engines (meaning if they break a belt, pistons hit and bend valves) which is not a pretty sight...
Jul 28, 2008 | 2006 Hyundai Tucson
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
