Your on the right track. Have you scanned the PCM, what codes did you get? If not and you changed the vehicle speed sensor,(VSS) did you check the (OSS) output shaft speed sensor, it will cause torque converter lock up and hard shifting and that pesky OD light flashing. I have also found that clutch packs inside auto tranny's dry out. Ford and some aftermarket companies sell a fluid that will recondition the clutch packs.
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Electro help
The majority of laptops will display a solid green, blue or
purple battery light to indicate that the battery is fully charged. Most
manufacturers indicate that a laptop is in the process of charging by
displaying a solid or blinking green, orange, blue or purple light. If
your battery indicator light is green, blue or purple, the battery is
probably functional, regardless of whether the light is blinking. If the
light is solid orange, the laptop is probably in the process of
charging.
Battery Error Coneventions
Many battery manufacturers use rapidly blinking lights to
indicate that a battery's charge level is low. In general, a laptop will
rapidly blink orange or red when its charge drops below a certain level
until the computer is plugged into a power outlet and charged. If your
laptop's battery indicator continues to blink rapidly in orange or red
or if it remains red even when it is plugged into the charger, it
indicates a problem with your battery or the charger.
please read and execute the commentaries. God bless you Charging Conventions
charging.
try to acces the menu and to reset the display settings. try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
1.) Most of these sets have a receiver built into the back(large metal box on left side as you look from the back.)
2.) Two possible reasons for green light constantly blinking(it is the receiver booting up if the set is disconnected from power---light should blink for about 70 seconds and go out).
3.) First reason: The recessed micro switch on the keyboard marked reset may be bad--does not happen a lot but it does happen. Easy way to see if this is the problem is to remove front speaker grill---and inspection plate behind it---from the keyboard you should see one or two groups of wires(they come from the keyboard) follow them to the right and unplug both(they are different and marked with letters). This takes the keyboard out of the circuit---you should still be able to turn the set on with your remote(remote receiver is behind the screen.) IF SET NOW WORKS YOU HAVE TWO CHOICES--USE IT ONLY WITH THE REMOTE OR HAVE SOMEONE REMOVE THE FRONT KEYBOARD AND UNSOLDER THE RESET SWITCH--the switch can be replaced without replacing the keyboard(it is a small circuit board with all the micro switches on it.)
4.) If disconnecting the keyboard does not fix the trouble---you have a problem in the "Receiver"----it happens on these sets and usually is repairable--Mitsubishi no longer sells this part and it was very expensive when they did---if disconnecting the keyboard does not cure the problem---let me know and I can give you options for getting the receiver repaired.
5.) Let me know if you have questions and if you need more advice reply to this post here.
I do this here for free so if this information helps you take a minute to give me a vote here---I am here to help people.
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
