Question about HP ProBook 4530s Notebook
Powerbutton issue my powerbutton stuck in and i cant click it anymore and the laptop starts itself when i connect the charger
Posted by Ahmed Youssef on
Larry Ng
  • HP Master
  • 6,445 Answers
Its broken buy a used or new switch assy, on ebay.
Posted on Jan 14, 2022
I have a Samsung N150, it will not switch on even even I put in the charger, it shows no light.
  1. pull out the battery after that u put the charger
  2. if the you have the same problem change the charger
  3. if still the same problem see the charging port of laptop
  4. if the problem is not solve check the power ic on mother board
I have replaced the Fan for IBM R61e but the laptop is not starting .There is nothing on the idsplay just couple of indicators .
Does it make any sound?
Does something show up on the screen?
Are you absolutely sure that the fan is OK and spinning after you start it up?
Did you plug everything correctly back? For example didn't you forget to connect back your power up button part of keyboard?
You can try to remove the keyboard and other unnecessary parts like CD-ROM. Try to start it without keyboard and the powerbutton board. But be aware this may damage your computer if you do it improperrly.
My U200E won`t charge unless it`s completely dead and the touchscreen won`t work anymore
Hi Bell, please don;t panic. Let us try to solve it.
> remove -- and don't replace -- the battery, than connect the charger and turning on the Laptop.
> also check the charging LED is turned On.
> if its working than check the battery else check the charger.
Feel free to revert back if issue not resolve.
Thanks
My compaq 610 wont start up. went i connect de charger the powerbutton lights goes on en off.
When the power button blinks do you hear the laptop fans run on full speed? If that happens its because your laptop is overheating and is trying to cool down. It will not turn on until it cools down to protect from damage due to heat.
Use your laptop on a hard surface and dont block its vents with anything. If you want to use it on bed keep it on a laptop cooler or a thick book to allow ventilation.
If laptop doesnt turn on at all, the motherboard might be damaged. Take it to repair shop and check whats wrong.
Plantronics ml10
Same problem for me: I start chargering (red light) and when I unplugged It don't power on anymore.
The solution for me was resetting the unit. Follow next steps:
-Start charging the ML10 (a red light will appear)
-Press PowerButton and Volume(-) (a blue/right light will appear for less than a second).
- Voila! It comes to life!
1helpful
2answers
Nokia phone not recharging
Technically, It would be an old battery issue, or the charger itself, try using another charger, if the problem still occurs, maybe it's the battery or your's phone's charger jack had a hardware issue.
Laptop Power
Not the charger. It is either the battery or the charge circuit in the laptop. Most are on the mother boards but some have a changable dc to dc inverter board
HP ProBook 4530s Notebook Logo
Top HP Computers & Internet Experts
Ekse
Mehandi Husain ...
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
