Washing Machines Logo
K
Kari Nichelson Posted on Mar 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 400 series washer won't finish cycle,I have to turn the dial to drain and spin to finish the load
The washer is about 2 yrs old and this seem to have started after it got of balance with a load
  • Teresa Eames Oct 03, 2019
    Mines doing the same thing. Did you figure anything out on it
Ed Mac
Level 3:
  • Master 731 Answers
  • Posted on Apr 01, 2016
Ed Mac
Master
Level 3:
Answers
731
Questions
0
Helped
252410
Points
2239
Sounds like either a wire has come loose from the switch or the motor that spins the the ( may be integral part of switch ) has gone bad.
2answers
My Kenmore series 80 washing machine will not automatically do the drain, rinse & spin cycle.
please rotate your cycle dial in the opposite direction of its usual motion by 90 degrees (probably counter clockwise). Then you can run the cycle again and the drain/spin/rinse should work. Otherwise, please power cycle your washing machine.
Thank you.
1helpful
Kenmore 800 series washer not draining; stops at that cycle; have to manually turn dial to spin/drain cycle to get it to finish; Need to trouble shoot n fix. Help?
After you advance the knob, you are saying that it will finish the rest of the cycle? If that is the case, more than likely, you will need a new timer for your washer. Hope this helps!
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
1helpful
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Alexander
vince
