Question about Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
I keep getting an error message stating to install a waste toner box and close all doors.
I need to get a print job done now and don't have time to get a new waste toner box. I emptied the original box and it still doesn't work
Posted by Chuck Wright on
Kubek
    New Friend:
  • 5 Answers
Try to find a little small window on your waste toner box
it must be cleared by vacuum for example
Posted on Mar 07, 2016
R.A. Ellis
  • Konica Minolta Master
  • 12,731 Answers
Printers usually have a waste collector where excess toner is collected. Obviously, yours needs to be changed.
Ive replaced the waste toner box in a Brother MFC-9140CDN but the replace WTB message still continues and I still can't print. Its supposed to last for 50,000 pages, its done 8,000 pages.
Check your operator''s manual for a reset procedure. If this doesn't work, pull the AC plug overnight, if the error isn't stored in a flash memory, this may help reset it.
Jun 25, 2015 | Brother Office Equipment & Supplies
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
I keep getting a message install waste toner box and close all doors, i have tried all that and the message keeps coming, the waste toner box is empty.
remove the toner, check if there is any debris perhaps also blowing in the guides of the toner. Give it a shake and refit it.
Close the doors and if you still get the message you need to replace the empty toner
Mar 11, 2015 | Office Equipment & Supplies
When I go to print it starts beeping and telling me to check waste toner box?
The waste toner box is located on the right hand side of the printer. There is a door/cover that opens up on the right side. It is a milky white plastic container. Check to make sure it is there and installed properly and the door is fully closed. If all that is correct it my be full.
There should be a new waste toner container in the toner box (along with a toner). The toner and waste toner are normally replaced at the same time.
If you don't have a new waste toner container you can tray emptying the one that is in the printer BUT be very careful. The toner is a fine powder and can get all over if spilled. If you ever spill toner never use water or any other liquid to try and clean it, that will just turn it to a liquid ink.Brush it off your cloths and vacuum it up.
If you do try and empty the container and the machine continues to tell you it needs to be replaced it can be because there is still toner on the inside of the toner container and the sensor is seeing it there.
I hope this is helpful,
Shawn
Jan 29, 2011 | Kyocera Mita FS-3820N Laser Printer
Install the wate toner box and close all doors
Hi the waste toner box is located at the rear right of the copier. You'll need a Phillips screw driver to undo the 1 or 2 screws that hold on the rectangular panel in that area. Inside you'll find a tall thin box which is the waste toner box. May be that it just needs emptying out (suggest double bin bag)and re fitting.
There are also some counters in service mode which may need resetting though.
Mar 23, 2009 | Canon imageRUNNER C5800 Copier
Konica Minolta BizHub C550 Error Message
TRY THIS
turn the machine off from main switch on bottom right and hold down the UTILITY BOTTON AND TURN MACHINE ON
Jan 15, 2009 | Office Equipment & Supplies
Problem with printing
CRU Fuse Error The toner cartridge is
not installed correctly.
Install the toner cartridge
correctly. See “Replacing the
Toner Cartridge” on page 8.4.
www.zinetic.o.uk
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Oct 31, 2007 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW Logo
537 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
