Marantz SR-5200 Receiver Logo
Question about Marantz SR-5200 Receiver
After 5 min. working time(5 min after the receiver was switched on) the sound from the left speaker disappear.(no matter which surround mode i use). Any idea?Thanks
Posted by ivaylo kasteliev on
jhnolson
  • Marantz Master
  • 822 Answers
The simplest way to trouble shoot is to swap the speaker connections at the back of the amplifier. If the problem follows the speaker than a connection, possibly internal to the speaker fails as the speaker warms up(voice coil).
If this swap indicates that the amplifier is the problem swap the channel inputs to confirm that it is internal to the amplifier. Also try a different source to confirm it is not the output of the source.
If not, than the amplifier would appear to have a problem. This would most likely require a qualified technician to repair.
Tthese amps are robust and you may have to choose an alternative speaker pair(example sub-room or speaker set 2) to maintain the set up you have. Also a internally shorted speaker may have the impedance low forcing an output protection feature.
After 5 min. working time(5 min after the receiver - 26121267-sv2pozd4hmoj1gs3kz5bhtfq-3-0.gif
Posted on Mar 07, 2016
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
2helpful
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
I bought this from a thrift store for $10 bucks. It works fine in normal mode but when I switch it to surround mode everything turns into static. No matter what input I select or what surround mode it's...
It sounds like you are activating a test mode to set your surround speaker levels.
Usually you should do this before using any surround sound modes.
If you could post the exact model; we can search for an owners manual.
I get full surround while watching a movie throough the dvd player /blue ray player but cant get surround sound through my normal tv and yes i have a cable box if it matters ,, when i am in stereo mode i...
If you have the users manual for the unit, go to the troubleshooting section or the section that explains how to set individual speaker levels and effects and reset the balance there. It sounds like somebody tried to set things in this way but maybe got a little confused and turned off the wrong selections. There should be a demo program built into the receiver that allows the listener to hear all of the different settings available with the different effects also. Hope this helps.
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
2answers
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
No surround sound
if the unit has no digital dvd 5,1 input it will not play 5.1 output, unless the unit is switched into a virtual surround mode(theatre/etc) mode try with a new dvd film with a digital glassfiber cabel if it shows 5.1 on the display of the receiver. if it shows 5.1 digital surround than the end stage of your surround is blown and needs to be replaced
pauliesbouth
2answers
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
