Binatone 100 Latitude Walkie Talkie twin Blackyellow Logo
J
Joan rowatt Posted on Mar 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Both phones are displaying out of range please advise
John L radiodude365
Level 3:
Master:
  • Binatone Master 570 Answers
  • Posted on Jun 03, 2016
John L radiodude365
Binatone Master
Level 3:
Master:
Answers
570
Questions
0
Helped
209793
Points
1236
Walkie talkies talk to each other. Try transmitting (talk to each other) so they receive a signal first. Do it in the same room. The try for range. It is not much. Even for a GMRS radio, these are low power and short range. Under 2 miles, must be able to "see" each other.
Blank display on fridgidaire model plgs389ecc
Good Afternoon Friend,
I understand that you have a blank display on your Frigidaire range, model# PLGS389ECC. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock, and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
What's wrong with it?
Good Morning Friend,
I see that the display panel is no longer working on your Frigidaire range, model# FEF355. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Sometimes the control boards inside your appliance can miscommunicate with each other and can cause things such as this to occur. Most times they need the hard reset to get them communicating again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. Hope this is helpful.
-Best Regards-
WP
1helpful
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
1helpful
I had my oven on self clean and now it won'T shut
Hello. i can assist you. the oven will not unlock until it is relatively cool and safe to open the door. This may take an hour or more.
2helpful
2answers
LG FLAT TOP KITCHEN RANGE
in power surges generally there should be an internal bus fuse that needs to be reset. this is to protect the internal circuitry and prevent not only the main board but fire as well to access this there is a rear panel on back of the unit. the reset should be in behind it near the power chord. please rate the solution.
2answers
I have a Jennaire range and the control panel no longerworks to control turning oven on etc....first the LED display had went out. Now no touch pads work!
The clock is a very common problem the only way you can fix the LED display and it also controls the oven...replace the clock
Top Binatone Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Binatone Radio Communication Expert? Answer questions, earn points and help others
