Question about Audio Technica Audio Players & Recorders
Audio Technica LP 120: 1st issue:Even after cleaning records get some noise. 2nd issue: No sound in middle of Olay then all of a sudden get sound..again no sound then get sound again. Please Help.
5 Suggested Answers
robotek
Graeme Ross
  • 1512 Answers
SOURCE: No volume from Audio-Technica ATM410
the mic you mention is a dynamic mic, and needs a mic preamp to get decent levels for most computer sound inputs
Posted on Dec 14, 2007
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Posted on Apr 24, 2009
cjsound
Cody J Simpson
  • 26 Answers
SOURCE: I dropped the audio technica at2020 mic and when i
Most likely it could be two things either a connection is not getting current anymore. my 2020s have went through hell and no problems. or the other suggestion is that your phantom power is not being sent from your preamp to the microphone (not to make you feel stupid, just a reoccuring problem on this board.)
Good Luck, Cody J.
Posted on Dec 17, 2010
Anonymous
SOURCE: hi i am using the
This mic has a 10db pad or attenuator switch near the bottom of the barrel... make sure you haven't accidentally engaged it.
If that's not.... it try changing the lead. Also the power supply on your preamp could be failing.
These are a few cheap things to try before spending money for fixing.
Posted on Jan 09, 2011
technical114
Stelios
  • 1851 Answers
SOURCE: My Audio-Technica AT4033CL mic worked
The most common problem at these cases is a loose of the phantom power. Take a closer look at all the connections and check that the phantom power supply voltage is enabled at the mixer. If it's possible check with a multimeter that you have 48V DC at the 2 - e pins of the XLR connector.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Feb 12, 2011
I've got an Audio Technica LP-1240 turntable with a Shure M97xE cartridge. I've had it for several days now, and it's been playing fine. I just got a record cleaning kit (Tonar cleaning brush with a bottle...
A damaged or worn stylus will effect all records not just one. I don't know what D4 fluid is, but if there was some still present on the record it could have got inside the cartridge and done some damage to it.
Sep 21, 2013 | Audio Players & Recorders
My mic keeps getting this popping noise wen i record, i have a pop filter an it's not a wind noise it's a crackling sound
Is it a condenser mic? Either your mic is bad or you need to add a compresser to your signal path...
Feb 09, 2010 | Audio Technica Audio-Technica AT2020...
Connect turntable
http://www.turntableneedles.com/Pre-Amps_c_4.html
I am pretty sure that model is NOT "USB" so you would need to hook it up through a preamp as shown in the drawing at above link.
then goto downloads.com and do a search for "cd lp" without the quote marks and you will find a lot of free software to load in the computer in order to record the LP's as they play into the sound card.
hope that gets you started...
Feb 16, 2009 | Audio Technica AT-PL50 Turntable
on page 5.
enough
cartridge body.
Sep 02, 2008 | Nakamichi AV-7 Receiver
Audio Technica AT-LP2D
Mine had the same problem. It was under warranty and Audio-Technica replaced it promptly.
Mar 02, 2008 | Audio Technica AT-LP2D Turntable
No matter what I do, I can't eliminate the occasional skip...
Try cleaning that lp with an anti static felt record brush, and look for either groove glide or d4 cleaner....Sounds odd, but ive ad records kept in tip top, climate controlled, and funk still gets in the groove.
Oct 29, 2007 | Audio Technica AT-LP2D Turntable
139 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
