Consoles do this if they've been tampered with, according to Microsoft's help page. In bad news, you can't fix it.
In good news, you can still play your games offline. Restart your console and select "No" when the update prompt comes up.
You won't be able to use Xbox Live, but you'll still be able to use your console to play local games.
http://support.xbox.com/en-US/xbox-360/errors/error-code-c800-0036
SOURCE: Update Failed Message on Xbox 360
SoulSlinger
Mar 27 2009, 08:09 PM
Post
#7
X-S Enthusiast
Group: Members
I had change of heart, the guys over at 360mods prevailed on me to release this for free.
So for all to see , here is how you fix the update failed error in all cases:
The
error seems to happen when the 360 is unable to read from the update
source during the update. The only time I have actually seen it occur
was when updating from a backup, which is a common cause Ive read
about. The other common cause is an onset of RROD during the update. Im
not sure what causes the hard drive error. Either way, the solution is
simply to supply the 360 with the correct update file either on a CD or
a USB stick. Now here's the rub, it has to be the exact same update
file as the one that failed. Not a problem since I've made a nice
torrent file with all of the updates to date here:
Google
The
version number is shown at the bottom of the error screen. PV is for
previous version and CV for current version. Just put the file matching
the current version (the one you are updating to) on a USB stick, (i.e.
E:/$SystemUpdate) put it in your 360, and power up. If you have the
right one it will finish updating and boot to the dashboard. Voila.
This
has worked for me on 7 consoles so far. 3 of them said they couldn't
detect the hard drive and the other four the update disc, so this seems
to work in all cases. I hope this can help some people out.
SOURCE: Update failed xbox 360
Simply hold down the sync button before turning on the console. Continue to hold the sync button until the console boots to dashboard completely. This will clear any failed updates. If you still have this issue after performing this you will more than likely need to send your console in for repair.
SOURCE: my xbox 360 keeps saying update failed n i cant
With the console off hold down the sync button. Continue holding the sync button and power the unit on. Holding the sync button should clear the failed update and allow you to boot to your dashboard.
SOURCE: wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
