Question about Panasonic VIERA TC-P50ST30 50-Inch 1080p 3D Plasma HDTV
What does 14 blink code indicate? - Panasonic VIERA TC-P50ST30 50-Inch 1080p 3D Plasma HDTV
Posted by Eric Bubniak on
    Top Expert:
  • Panasonic Master
  • 76,416 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
LED blinking codes to many brand TVs are given. Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Mar 07, 2016
SONY KV-29CS60E LED BLINKING 14 TIMES
It is unusual. Count the blinking codes once again.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 15, 2016 | Sony Televison & Video
After turning the AC off and again on the indicator lamp blonks 14 times and again it pauses for 5 sec and again it repeats the same with 14 blinks
Brand name and model number?
Sep 09, 2016 | Televison & Video
14 red blinks wont stay on, I'd love to find the service manual to understand what 14 blinks means
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 06, 2015 | Panasonic TXL42S10B 42 HDTVReady LCD TV
14 blinks on my Panasonic TC-P50S30. Any Ideas?
Nov 19, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
Why is my panasonic tc-p46x3 is blinking 14 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Aug 10, 2014 | Panasonic Viera Plasma TV TC-P46X3
I have Sony Bravia 46in model kdl-46w4150 it was working fine then just shut off and red standby light blinking 14 times. I've unplugged and tried to turn back on but still just goes to red standby light...
14 times blinks is a rare case to Sony Bravia sets. Just count it one more time.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Aug 06, 2014 | Televison & Video
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My carrier unit is blinking 5 slow blinks and i can't find the fault codes to determine the problem. the model number to this unit is 58wav091-14
Dont know about yours, but the models we carry use fault code 5 to indicate low pressure/charge in the system.
Nov 30, 2010 | Carrier Heating & Cooling
Panasonic VIERA TC-P50ST30 50-Inch 1080p 3D Plasma HDTV Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
