A
Anonymous Posted on Mar 06, 2016
How do I set for double sided printing - Office Equipment & Supplies
Luis
Level 1:
Habit-Forming:
New Friend:
  • Contributor 11 Answers
  • Posted on Mar 06, 2016
Luis
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
11
Questions
Helped
4533
Points
23
Go to advance setting and set for double side printing
Rabbit Brains
Level 3:
  • Master 575 Answers
Rabbit Brains
Master
Level 3:
Answers
575
Questions
Helped
182687
Points
1598
First make sure your printer is capable to print on both sides. Go to devices/printers on your computer, right click on your printer icon, select printer preference, select shortcuts, select print on both sides, click ok/apply
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
2answers
How can I do double-sided printing with my Canon MP460?
Hi there!You printer does not have an automatic duplex(double-sided printing)so you have to make a manual double-sided printing.When you start to print something , in the widow of the printer click on the preferences and look for the option "Print on both sides" or "Manual double-sided printing".When you start the printing the printer will print page page 1,3,5,7..... on the one side of the paper.After the printer finish you have to take the papers and put them back in the printer with the other side of the paper.Then the printer will start print page2,4,6,8,.....If you need any other help please replay!Tghaky for using Fixya!!
Double-sided printing
I believe unless you have a 'D' after the model number you do not have a duplex printer.
Double Sided printing of PDF files
you have to set the printer properties to do double sided printting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
My printer keeps printing double sided when I need
You will need to change the printer settings in your computer. The duplexing / double sided printing is obviously turned on.
Printing everything double sided
go in youre ip address, log in as admin, chooce print tab and there is a print tab, there is a default options, and choose double printing off
2answers
Double sided printing
In this printer u dont have duplex print mode,u can use only manully.
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
1helpful
1helpful
There should be a setting in the 2-sided properties for binding orientation.
For a MAC, do this:
On the File menu, click Print.
Open the Two-Sided Printing panel.
Select the option to print on both sides.
Select the binding orientation by clicking the appropriate icon.
Change any other settings, and then click Print.
k24674
ADMIN Andrew
ADMIN Andrew
