SOURCE: Microwave Oven Model MMV5207BA/BC
E13 is usually a bad door switch or door switch mount.
The first step is to unplug it from the power outlet for one minute, then plug it back in and try it again.
If it still fails to heat, I would check the door switches and door switch mounts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Maytag microwave light bulb MMV5207BA/BC
A 20W, 120V replacement xenon halogen bulb with G8 base can be purchased from Lowe's.
SOURCE: is the bracket for model MMV5207BA/BC made to
MY MMV5207BA/BC starts running for no reason. We have to raise the door by the handle to get it to stop running. Is there any solution for this problem?
