Question about Hitachi Office Equipment & Supplies
I have hitachi le42h508 tv and I replaced the mainboard and now I need give a factory reset because the image is upside-down. I tried different codes found in the web but does not work .
    Top Expert:
  • Hitachi Master
  • 76,237 Answers
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Mar 04, 2016
5 Suggested Answers
Anonymous
  • 11 Answers
SOURCE: Rotating the image.
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
Posted on Feb 19, 2008
Anonymous
  • 24 Answers
SOURCE: my projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Posted on Apr 12, 2010
Anonymous
SOURCE: Image Upside-down
acer projector cuts off after a few minutes.
Posted on Apr 20, 2010
haas1703
  • 69 Answers
SOURCE: Hitachi projector image is upside down
you can chance it in the menu
Posted on Apr 21, 2010
Moonstarr
  • 8 Answers
SOURCE: upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Posted on Dec 06, 2011
Sharp Aquos Smart tv flipped screen
Hello Danny,
Have you tried resetting the TV to factory settings?
I would suggest to try that and see if it works..
Good Luck
Jun 10, 2017 | Sharp Televison & Video
My hitachi LE42H508 still wont turn on after replacing power board. Power cord has power coming in but still nothing. No noise lights. Help
Your main board is probably dead and is not allowing the power supply to power up from standby mode. I have seen a few of these TV's fail recently and was able to fix them by replacing the eeprom on the main board.
Jul 23, 2016 | Hitachi Televison & Video
HITACHI PROJECTOR IMAGE IS UPSIDE DOWN
Go to Settings/Advanced Settings/Setup/Mirror and change to NORMAL. It'll probably be set to H:INVERT.
Sep 10, 2012 | Hitachi Gst Hitachi CP-X2011 Projector
Picture is upside down
Your projector is set in ceiling mode. This is for when it hung upside down from the roof. Without a make and model it's not possible to give exact instructions but if you search through the on screen menus and either find "factory default reset" or the image/picture mode section you will be able to reset it.
Feb 18, 2011 | Office Equipment & Supplies
Upside down image
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Upside Down Image
Hi there
Go into the Menu - you'll see a subfolder that either reads : Flip image or Mirror.
Go into this subfolder and change the image. If it doesn't work or you still can't find it notify me and I'll draw the user's manual and mail post you the exact steps.
Apr 01, 2008 | Hitachi ED-X3450 ED-X3450 PROJECTOR...
Hitachi with blue out of focus or ghost imaging and have tried magic focus many times!
Good Day,
When you turn down the BLUE the TV will give a yellowish picture. That is why the TV has three CRT's, it needs all three colors. The problem most likely lies in the TV's Convergence Circuit. To repair yourself get KIT 10 @ 1-800-458-6053 or www. bdent.com. If not call a Factory Authorized Service Center and have them give a written estimate, avg cost $550.00.
good Luck, big IRISH.
Feb 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
440 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
