Televison & Video Logo
Jonathan Peace Posted on Mar 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I connect a bluray which only has HDMI output to the TV
Dexter Abdul
Level 2:
Habit-Forming:
New Friend:
  • Expert 36 Answers
  • Posted on Mar 02, 2016
 Dexter Abdul
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
36
Questions
Helped
6751
Points
116
If your TVs HDMI input port is used you can use a splitter like this one: http://www.amazon.com/gp/product/B00OHHG768?keywords=switching%20hdmi%20splitter&qid=1456943391&ref_=sr_1_1&sr=8-1
to connect another HDMI device to the TV
If your TV does NOT have an HDMI input you need to convert the HDMI output from the blu-ray to RCA like this one:
http://www.amazon.com/Cater-Mini-Composite-Converter-Input/dp/B0149M9WFI/ref=sr_1_1?ie=UTF8&qid=1456943578&sr=8-1-spons&keywords=convert+hdmi+to+RCA&psc=1
but this actually will reduce the high blu-ray quality to a lower resolution
How to fix no sound audio on Panasonic viera when connected from hdmi 3 port to Sony bluray BDP s480 hdmi port?
Well, first make sure you don't inadvertently have the "mute" control on your DVD player turned to the "on" position. Does it work on HDMI 1 or 2? Play with it a bit. Connect it to other TV HDMI inputs and see what happens. Obviously, the video is getting through, just not audio. HDMI inputs on your TV carry both (unless there is a problem with one of them), as does the HDMI output on your Blue ray. Also, make sure the HDMI OUTPUT from your DVD is connected to the HDMI INPUT of your TV.
tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
When my blu ray player is on no matter what I do screen still says resolution mismatch, how do I fix it? Pushing play and stop does not help
Unplug HDMI cable. Connect Bluray to tv using composite video cable. You should then be able to access the bluray players menu to set the hdmi output to a setting that is compatible with your tv (see your TV manual for compatible resoloutions. Once set disconnect the composite video cable and reconnect the HDMI cable.
What are the best settings for the DMP-BDT330 Panasonic Bluray Player
Hello Myles, we recommend you connect the player with a HDMI cable and then set the player's output to 1080p.
1helpful
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
CAN I USE HDMI CABLE TO PLAY MOVIE THROUGH DAV-DZ270 TO A LCD TV ?
Yes. This is what you should do. Connect the Bluray players HDMI cable directly to your TV, then use an optical cable (usually around $20-40) to go from the Bluray player to the surround system. You will then need to enter the menu of the Bluray player and set up the Audio to be run through the Optical output instead of the HDMI. Problem solved!
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
1helpful
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
3answers
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Connecting blu ray to surround sound receiver to tv
Hi, I have just completed this installation myself.
You are correct, HDMI to Amp Input from Bluray and then HDMI from Amp output to TV. Coloured cables are not required to operate the bluray now.
Good luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
