I know how to wire the processor to the tape loop but don't know how to tell the AVR to enable it for a given source.
SOURCE: CDR/ipod Not Connect wondow message
Select another function, fx V. Aux, then press menu-button. The display should then show "Ipod assign". Use select to find "Ipod: none" and press Enter...
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF]
AVR-3300/1
3.3E*
SOURCE: I have Bose 901 speakers attached to a Denon
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
SOURCE: How do I turn tape
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Oh, but you don't have pre-outs. Bummer. Most AVR's will NOT pass digital sources to analog tape outs. Page 40 of the manual confirms that.
no can do. sorry. You need Pre-Outs to feed an external amp.
--- Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast. --
http://4.bp.blogspot.com/_TaoBB_L8lt0/TDi__0VSpoI/AAAAAAAAACc/uS9ODAazZi0/s1600/HPIM0718.JPG
If you wanted to Equalize a single external analog source you would have to connect the EQ Line output to either of the two analog inputs ("DVD" or "Video" in your case) and connect your external source to the Playback jacks on the EQ.
http://www.retrevo.com/support/Harman-Kardon-AVR-1600-Receivers-manual/id/23554ag018/t/2/
Okay, back to the hook-up:
You have to select any available 'tape loop' containing an overrideable analog 2-channel Out and In. That would be Video 1 or Tape on the HK.
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
The EQ has its own Tape Loop(s) to replace the one it uses. Actual Tape Decks or Processors can nest into those loops and be engaged or bypassed via controls on the EQ or Processor.
The following is some boilerplate I made up that should explain some usage limitations.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In; Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
Be advised that the engagement of any device in a Tape Monitor loop on most late-model Audio/Video Receivers (*) will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
* But not the HTR-5063.
Okay, back to the hook-up IF you had a Tape Loop:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Amp-, Rec-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Amp-, Play-Out.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
So, to sum up, you can only use the EQ for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
[Or you could obtain a dbx Program Route Selector (check eBay, I highly recommend the 400x, of which I have two) and it would, while only using one receiver Tape Loop, allow for three discrete attachment paths for processors and three for tape decks with the added flexibility of front-panel selection of any and all, with the processors being before, after or between the source or tape decks. Plus it has a dedicated facility for an inline dbx Noise Reduction Processor that can also be juggled around via pushbuttons. Pretty neat.]
