I think I would replace the boyfriend for a real man
Hi:
First off, It makes be a bit concerned that you are planning on trying to replace your starter yourself and you need help identifying it.
Gold Star for gumption!
Here's a link to a video that shows how to replace a starter.
https://www.youtube.com/watch?v=1cB8tuyxyQk
Hope you find it helpful.
Cheers
SOURCE: where is the starter located on the 2004 chrysler
look around the bottom of the motor at the rear of the block on both sides. it should have a thick battery cable attached to it and a couple of smaller wires attached to it, one on the solenoid and one one the same terminal as the thick battery cable
hope this helps you
SOURCE: 2004 mazda MPv Where is the location of cyl. #6?
The firing order is 1-4-2-5-3-6. The cylinders are, front bank is from drivers side to passenger, 6-5-4 , and 3-2-1 at the firewall.
SOURCE: 2000 Solara Shift Solenoid Malfunction
i can send you step by step instructions with diagrams if you post your email address
SOURCE: Need help in locating starter on a 2001 mitsubishi
they at the back of the motor just at the top or could be at bottom at back of gearbox
SOURCE: Diagram of thermostat location on 2004 Chevrolet
2002 Chevrolet Cavalier 2.2L SFI OHV 4cyl
2.2L VIN 4
Fig. Remove the thermostat outlet bolts and outlet
2.2L VIN F
Hope helps (remember rated this)
Testimonial: "Great! Could not find this anywhere else."
