Question about Video Cameras
Elu flip over 110v saw?
Is the capacitor on my Elu flip over saw a dual capacitor and what are the specifications of capacitor as the writing on the original one has faded
Posted by Joe nolan on
1 Related Answer
bushie_brown
Bushie
  • 92 Answers
SOURCE: Capacitor?
REPOST with more info, hand saws do not have capacitors.
Posted on Mar 01, 2016
Capacitor?
Mar 01, 2016 | Heating & Cooling
Elu 172. How do I remove flip top and the safety guard to clean?
Hi mate this is in the wrong category but i have an elu flip saw and to remove the guard you take your blade off and guide bush and remove the circlip and the guard pops off but u need to make notes on where the guard return spring fits through a hole on guard so as to replace, and remove the bolt with the screw driver slot in and washer / spacer to detatch the folding arm inside the guard, i will check mine and jog my memory then get back to u,does yours have a duel size bush for different blade diameters / centres. Paul
Sep 19, 2015 | Garden
Electrial drawing for a flip over saw model COD2000FLS
Check out the links associated with these images. I suspect it is identical to an ELU
Elu tgs172 Google Search
Sep 24, 2014 | Saws
My elu flip saw shorts out when I flip it over from a table saw to the chop saw, it works fine as a table saw
There is a bridge rectifier its a little black round piece in the box of the red green switch that must be replaced i see you have got a gray or bleu ELU not a dw 743 i know this problem that is what i know buy a new rectifier or place 4 diodes 1n4007 in a bridge if you know how to do this to make AC to DC its only for the magnet switch and connect the 4 wires to it .
May 28, 2014 | Dewalt Dw743n 240V 250Mm Combination Saw
Elu tgs saw wont start up flip over
i have no clue what you're talking about
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Aug 01, 2012 | E-Machines W3107 (RBW3107) PC Desktop
I have an elu flip saw that works as atable saw but not as a drop saw is there a wiring diagram so i might trace through the fault
there is a cable that runs from in behind the drive belt and around and under to the main switch block . because of the flipping action it can open circuit . youllhave to check it with multi meter . good luck old but good machine.
Nov 15, 2009 | Saws
Dewalt DW742 won`t start
These machines have an induction motor and need a capacitor to give it a kick start. Is it humming when you push the button? If so I would check the capacitor and you will probably find the fault there. Otherwise it could be a problem with the table switches. When the table is flipped it pressesd against a button which tgells it which on switch is operational. If something has blown there it would disable both buttons.
Oct 19, 2008 | Dewalt DW746X 10" woodworker's table saw...
Video Cameras Logo
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
