The Epson Artisan 835 waste pad is located in the printer's waste ink compartment and is designed to absorb any excess ink that is generated during the printing process. Over time, the waste pad can become saturated with ink, which can cause issues with the printer's performance.
To clean or replace the waste pad on an Epson Artisan 835 printer, you will need to follow these steps:
Turn off the printer and unplug it from the power source.
Open the printer's cover and locate the waste ink compartment.
Carefully remove the waste pad from the compartment.
Clean the waste pad with a damp cloth, or replace it with a new one if it is heavily saturated with ink.
Reinstall the waste pad into the waste ink compartment.
Close the printer cover and plug the printer back in.
It's important to note that this process can be messy and you should use gloves and old clothes to avoid getting ink on your hands or clothes. Also, some printer models may have a different process to access the waste pad, you might need to consult the printer's manual or Epson website to know more about your specific model.
The L110 needs the WICReset utility to reset the waste ink counter and a key to do that too. I believe the WICReset tool will also reset the ink levels without needing a key so if you can source the necessary bulk ink locally you should be able to get printing again.
hi
I want a free software to download to reset my printer and I tried in SSC Service Utility v4.30 but software don't have epson L110 model so, please help me to find right software to reset my printer. Thank you [email protected]
We are not advice to clean WASTE INK ABSORBER.
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter. The WASTE INK ABSORBER KIT is approx. USD10/pcs
First, we need to know what model # it is. A lot of the epson printers have a sponge in the bottom of the printer that the waste ink goes into. The waste ink comes from cleaning the heads. Everytime you turn on an Epson printer, it runs a head cleaning so your best bet with epson printers is to leave them on. You can get waste ink containers for most model on several ink supply websites, but you have to reset the waste ink notification before it will print again. There are several ways of doing this with the different printers, but you can download a program to help you. You can download it from here:
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
Select the connected USB port number from USB PORT
Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Your printer has a built-in waste ink tank for the ink used during
print head cleaning. As time goes by, the waste ink tank gradually
fills. When the waste ink tank is nearly full, you should receive a
"Waste ink warning" error when you print. Press the RESUME button on
the printer to cancel the error so you can continue printing. Before
the waste ink tank becomes completely full, have the waste ink tank
replaced.
