Question about Vehicle Parts & Accessories
How can I operate the A5.600 system manually because remote not working?
Need manual for operational issues
Shaw Direct - Troubleshooting Remote Controls, Codes ...
www.shawdirect.ca/english/customercare/.../remote/RemoteC...
Shaw DirectTroubleshoot all your remote control issues with Shaw Direct satellite TV systems. ...Get familiar with the remote and its operation by reading our guide to remotes. ... Make sure you have a clear path between the remote and the infrared eye on your equipment.... Try re-programming the remote to talk to your receiver.
[PDF]Wireless Handheld Remote Control - Hayward
https://www.hayward-pool.com/.../manuals/AquaPodOperationsManual.p...
Base Station required: The AquaPod 2.0 requires that the pool control have a base ... Refer to the "Operating Status" section of this manual for an explanation of ...problems. Operation. The AquaPod 2.0 remote control offers users the power to
Jan 24, 2016 | Televison & Video
RCA Rtb1016we 300-Watt Blu-Raytm Home Theater System With Wi-Fi My remote is not working properly. It will not turn on. None of the buttons work except the OK button. I have installed new batteries.
There are a couple of things I can suggest might be wrong. First the remote has been dropped and is damaged internally. Second the system has a two remote operation. And somehow you have set it for an alternative remote. So the first remote is switched off. If you have the manual I suggest you look for how to reset the system. That should reset the remote to working. If you don't have the manual check the makers website. They might have a free PDF of it.
Jun 12, 2015 | RCA Audio Players & Recorders
Lost remote
check the following links for you answer
http://www.ebay.co.uk/itm/Replacement-Remote-Control-For-Sony-DAV-SC5-/271034128605?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item3f1ae498dd
http://www.ebay.co.uk/itm/Universal-Remote-Control-to-DVD-SONY-DAV-SC5-easy-to-use-TV-/110829587705?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item19cdf54cf9
http://www.ebay.co.uk/sch/i.html?_trksid=p5360.m570.l1313&_nkw=Sony+DAV-SC5&_sacat=0&_from=R40
if this does not help then no matter what you can always get a new one from SONY
ALSO PS*** check in your owners manual for info on how to program your new remote to work with your system
if you no longer have owners manual then follow this link
http://www.manualslib.com/manual/247682/Sony-Dav-Sc5-Instruction-Operation-Manual.html
Oct 20, 2012 | Sony DAV-SC5 System
2002 Ford F350, Door Ajar Light on constantly, Auto Locks don't operate, Auto Headlights don't operate(only manually), Dome Light does not operate when opening doors, Remote does not work. All
Your keyless entry system is going bad and you need a battery for your keyless entry system once you replace your battery with the new one thing should work properly
Feb 06, 2018 | Ford Cars & Trucks
Hello, I have had my Home Theate packed for a few years now. I have 2 Toshiba remotes. Neither of them operate the system. One is an SE-R0094 and the other remote is an NB001. I tried new batteries in...
The SE-R0094 is the original remote for the SD-KT50. So should work with it unless it's faulty.
You can get the service manual for the SD-KT50, that might give you clues as to why it doesn't work. It's free the manual, just type the model number into Google.
Jul 06, 2017 | Toshiba SD-KT50 System
I can't turn the blu-ray player on or off with the remote. I can however do it manually. I also cannot open the disc drawer either with the remote or manually.
So would it be safe to say the remote isn't working?
• Is the remote control being operated within its operation range of angle and distance?
• Are the batteries exhausted?
• Have you selected the mode(TV/DVD) functions of the remote control (TV or DVD) correctly?
Jan 11, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
My remote for the samsung htc550 home theater system does not switch back to the set top after I have switched it to my tv. I no longer have a working remote for it and do not know how to switch it back....
Press the BD Receiver / TV button twice in quick succession. The light should now be orange which indicates it will operate the Home Cinema system....Pressing it twice again in quick succession will turn the light green indicating it will operate the TV.....Unfortunately the useless operator manual with the system does not tell you this....
Apr 29, 2010 | Samsung TV Remote Control
I have an older Craftsman GDO setup. 2-3 button remotes,a manual hardwired push button operator and my wifes' car has been successfully liked to operate the opener as well. Up untill just a couple of days...
I suggest you look for a Chamberlain dealer in the yellow pages and explain what you have. You are looking for a 'universal receiver' that will work with what you have.
Mar 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
