Question about Sharp LC-40LE550U 40" LED TV 1920x1080, 60 Hz, HDTV
Sharp TV (LC-40LE550U) without picture, but sound is fine. Very weak image with flash light. TV can be turned on with remote with green indicator.
Hello there, The TV was used two years and stop working this week without any picture. Sound is fine. With flash light, very weak image can be found. Remote can turn on indicator green and turn the TV off. I checked power supply board. I measured voltages with connected LED strips as followed CN202 (yellow) pin1: 338 pin2: 281 pin3: 282 pin4: 228 pin5: 227 CN203 (black) pin1: 172 pin2: 172 pin3: 119 pin4: 119 pin5: 0 Without connection with LED strip as followed, CN202 (yellow) pin1: 338 pin2: 0 pin3: 0 pin4: 0 pin5: 0 CN203 (black) pin1: 0 pin2: 0 pin3: 0 pin4: 0 pin5: 0 Any suggestions? Thanks a lot.
  • Anonymous Mar 01, 2016
    Many thanks @ The Knight.
    Last night I checked TV again with flash light. This time I used a usb memory to play a video. I can hear sound and see very weak images only with flash light. Any further suggestions? Thanks a lot.
    Top Expert:
  • Sharp Master
  • 76,416 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Mar 01, 2016
Where can I find a service manual for SHARP LC40LE550U?
Try updating the firmware before repair /replace of parts.
I am sure you would have tried troubleshoot shown on page 38 of the user manual.
http://www.manualslib.com/manual/751149/Sharp-Lc-40le550u.html?page=40 Sharp LC 40LE550U Operation Manual Appendix Troubleshooting
Mar 02, 2016 | Sharp Televison & Video
I turn on the main power switch of my LCDTV #LC-22SV6U and the pwer indicator (RED) flashes. I cannot get the remote control to turn the indicator to green and give us a picture.
IT SEEMS LIKE THERE IS A FAULT WITH THE POER SUPPLY IN SIDE THE TV IS THERE ANY AMOUNT OF FLASHES OR ANY CODES ITS SENDING OUT?
WHAT BRAND OF TV IS IT?
Sep 25, 2008 | Sharp Televison & Video
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
LC-40le550u no picture... green light on
if powers on and has no video and no audio could be the main board, but first try this :
take a flashlight, turns on the tv and try to "see" the image while light up the flashlight against the screen , if you "see" something you have a bad back light inverter board.
below the posible parts number :
MAIN BOARD : Sharp 9JY0140CTJ05100
POWER SUPPLY/ BACK LIGHT : Sharp 9JY0940CTJ05000
TRY TO LOOK FOR AT :
www.bostonrecycling.net
or ebay
thanks
Oct 09, 2014 | Televison & Video
I was using the satellite remote to find another show when the TV picture went black, then a minute or two later, the audio stopped. The satellite signal is still there (It is being received by another...
Hello.
First you have to figure out location of problem. That means is it inside of your new TV or outside of it?
Best way is to connect DVD player with new set of wires to different input and make sure it is working fine picture and sound wise. If OK - connect it to the same input that you are using with satellite box right now. If it works just fine - problem is outside of TV and originated in box or connection cable.
If DVD player does not work on any input - you have to call your TV manufacturer and schedule an appointment for repair tech. It is should be free of charge because you have 1-year warranty.
Or you can simply return/exchange your TV at the store you purchased it from (depend on store policy).
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Picture flickers on Sony HDTV
Hi,It seems your ballast(board that powers light bulb) is going weak.The ballast was used to provide a lower voltage because lamp didn't use as much as brand new one. A newer one takes more voltage and when ballast doesn't provide as much power it will flicker or produce a dimmer image.I found the one for your tv here: http://www.discount-merchant.com/1091041-KDS-60A3000-p/1091041.htm?Click=48173 Good luck and God bless you!
Jan 06, 2010 | Sony KDS-60A3000 60" HDTV
Sharp LC-40LE550U 40" LED TV 1920x1080, 60 Hz, HDTV Logo
205 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
