Question about Boating
Trying to locate free instructions to remove and replace seals in 2006 Evinrude etech 75HP
Do not need a video need written repair instructions and diagrams
Posted by Sue Williams on
Danny
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 174 Answers
Hi Sue.
Try Boatinfo They have a wide range of manuals.
Good luck.........
Posted on May 20, 2016
3 Related Answers
Thomas F. Schneider
  • 2715 Answers
SOURCE: gear box oil leak
Here is a website where a manual for you outboard may be purchased.  Outboard Marine went out of buisness in 2000 and thus no parts of origial manufacture are support is available . Therir are secondary markets .    THe Lower case splits in half and their is a seal around the prop shiftm which is pressed in. The seal between the cases are cut o-rings which are placed and glued into place with gasket seal.
The water pump is located where the case splits a little bit higher. You must open the little port on the side and take out one of the screws to the connecting shift linkage to split the case. After splitting the case the drive shaft and water pickup tube(s) wil come out of the powwer head or the tubs may stick into the power head which is ok. Place the lower skag into a vice and remove the 4 or 5 screws to the water pump housing. Remove and replace impellor and impellor plate if available. If part(pieces) of the rubber impellor is missing flush out the tubes and the power head to remove them.   When reinstalling the lower unit use a flash light to make sure that the tubes return  to the proper place in the power head and the shift lever is resecured. If you need more assistance, just write back. I was an Outboard motor mechanic for five years about the time of your motor.
Posted on Dec 23, 2008
Anonymous
  • 6 Answers
SOURCE: CHANGE WATER PUMP IMPELLER FOR EVINRUDE OUTBOARD MOD# E28ESLETD
Crowley Marine Boat Parts & Diagrams have diagrams of all the components, and the catalog is easy to go through to pull them up, OEM and other brands, no cost for the images.
Posted on Jan 21, 2010
shujat_hussa
shujat_hussa
  • 24 Answers
SOURCE: Downloadable free repair manual
you can download this manual from here.
htttp://freedownloadbook.blogspot.com
Posted on Oct 29, 2012
I have a 1981 johnson 75hp charger. blew powerhead so i bought an evinrude powerhead that was omc identical. I have no spark. wiring issues.Thought johnson and evinrude was same wiring?
go google and type in --wiring schematics for johnson outboard motor 75 hp 1981 model --- and see if there is a pdf version for down load
repeat the search but change the name to evinrude and look for a pdf version down load
go to a dealer service center and see if you can get a schematics for each from them
while it can be expected that the wiring should be the same as each brand is made in a different factory there could be a slight difference in the wiring set up that is causing the problem
Aug 09, 2016 | Boating
I've recently bought a 15ft fletcher with a 75hp
check spark plugs & fuel injectors if they work fine.
Sep 29, 2014 | Boating
Can evinrude etech have a voltage regulator
Yes it will have a voltage regulator to control the output and not boil the battery. It will be a small sealed unit near the flywheel
Aug 15, 2014 | Cars & Trucks
Evinrude motor problems
clean the carb jets etc and check fuel pump diaphrams not hard or perished ! balance the carbs also !
Aug 05, 2014 | Sierra Outboard Starters Johnson/evinrude,...
Need online repair manual for evinrude 50hp outboard
how can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
May 10, 2009 | Boating
Replacing the timing belt on a 2002 Honda Odyssey
you need a haynes repair manual . it save you time. it shows you step by step . what to remove to get to timing belt or chain . show you photos how to set timing chain cam and crank timing marks.
Mar 15, 2009 | 2002 Honda Odyssey
Tub Seal needs to be replaced
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Aug 31, 2007 | Bosch WFMC 3200 Front Load Washer
Boating Logo
113 people viewed this question
Top Boating Experts
ray gallant
Moderator Canada
Moderator Canada
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
