Siemens IQ-300 WM14Q390GB White 598 mm Washer Front Loading, 8kg, A Energy Rating Logo
k
kevin blackall Posted on Feb 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove child lock from a siemans washer
CL wont go from display panel.
pro appl ser
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 75 Answers
  • Posted on Mar 02, 2016
pro appl ser
Expert
Level 2:
New Friend:
Cheetah:
Answers
75
Questions
0
Helped
10960
Points
209
The display will have a icon for a lock. It may be for one or two buttons to be held for 5-8 seconds to unlock. It's the same thing as locking it.
Cl code on LG inverter direct drive 9kg washer
The child lock feature has been turned on your washing machine and when the child lock has been activated the control panel will not work and the settings can't be changed either. To turn off the child lock feature press and hold the child lock button for about 3 seconds.
Trying to make a load, CL comes up wont let me wash cothes, help
CL usually means that the child lock (or front panel lock) has been enabled. This is useful when you clean the exterior of the washer without starting the machine.
Without the manufacturer and model, I can't identify the exact button or pair of buttons to toggle the CL on or off. However this will be indicated on the washer in a very small font. There are two patterns for the child lock feature. In one case, there will be a button with a small padlock symbol on it. This will be below the button or on a second line on the button. Press and hold this button for 3+ seconds or until you hear a tone or see the CL removed from the LCD panel. On other washers, there will be a line between 2 buttons with either the small padlock or a picture of a child's face in the middle of the line. Press and hold the two buttons together for 3+ seconds or until you hear a tone or see the CL message disappear.
I hope this helps. For an exact solution, please add the make and model of your washer. Then I may be able to give the exact button or buttons needed to toggle off this lock.
2answers
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
1helpful
Tub clean cycle
this is not tub clean..its child lock..kindly remove child lock frist,,,
The display screen is showing CL. Nothing is
CL is child lock. See your users manual for unlocking the child lock procedure. Usually it involves pressing 1 or 2 buttons for 3 to 5 seconds. Many machines actually have a lock button you press for 3 - 5 seonds. Others use the stop pause button.
Kelly
26helpful
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
239helpful
8answers
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Top Siemens Washing Machines Experts
vince
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
