Question about Fitbit Charge Wireless Activity Tracker Sleep Wristband Large
No display but it's syncing ok - Fitbit Charge Wireless Activity Tracker Sleep Wristband Large
Posted by Glenis Wearne on
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
Can't find sync on my lumina 520 phone?
First of all, turn your car on, and have it in park...
Push the Phone icon on the steering wheel. In a moment your center console (or display) will show Phone Menu, then Phone Redial... use the seek arrows on the steering wheel to move through the Phone Menu. When you find "Add a Phone" or "System Settings" then push OK on the steering wheel (or on the console). Scroll to Add Bluetooth Device, push OK. You will hear the Voice say "Push OK to begin pairing a device." Push OK, the console displays a 6-digit PIN.
Now go to your phone, to the settings, be sure Bluetooth is turned on, and then Search for Bluetooth Devices. In a moment the IP address may show but wait until it displays "Sync." Tap this tab and a second screen appears, and it prompts you to enter the 6-digit PIN form the dashboard, then push OK on the phone. In a moment the SYnc system will acknowledge the connection and ask additional questions. Push OK to conform and OK again to "Activate 911 Response," "Make Primary Phone" and "Download Phonebook." Watch you phone, it may have a screen (or two) pop up that what you to confirm to "Always Connect" to Sync (check the Yes) and then OK on the phone. When all is finished downloading (may take a couple of minutes), it will display Download Complete. Then push and hold the Phone icon on the steering wheel for a a few seconds and release. The Sync system should be up and active. Push the Voice button (the icon with the mouth & sound) and it will sound a tone and state "Sync, state your command." Then say "Phone" and the system will come back and say "Phone, state your command." Then either say "Call + (contact first and last name)," If it understands it will say "Calling (Contact Name) and begin dialing. Or say, "Dial," and the system will ask for you to say the phone number. It will repeat the number, if OK, then push the Voice button and say "Dial."
For more information, see this Ford Sync weblog: Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Cell Phones
I have a Samsung U-485 that I can not get synced to my Ford 5-door Focus. It worked perfectly until a week ago.
When you push the Phone icon on the steering wheel (with the car running and in park) after a few seconds the center console screen will first display Phone Menu and the Phone Redial... Then use the seek arrows on the steering wheel to scroll through the menu... When you see Bluetooth Devices, push the OK on the steering wheel. Use the seek arrows again the find Connect BT. Push OK.you will see the name of your phone, or the model number (use the seek arrows), when you find your device, push the OK button. Scroll to Return, and Push the OK to go back on the menu. When done press and hold the Phone icon for about five seconds the end the process. Be sure your phone settings have it's Bluetooth on, check to see that your phone "sees" Sync...
Now push the Voice button (the mouth/sound icon) on the steering wheel, after the tone, say Phone and Sync should have your phone active...
Jan 23, 2014 | Samsung Cell Phones
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Mar 14, 2011 | Sharp Televison & Video
U430 will not work with ford sync
I have the same problem. Trouble pairing but finally I got the SYNC to find my U430 and paired but the SYNC never connects with the phone.
Sep 17, 2010 | Samsung Cell Phones
My nokia 5800 screen is broken and i want to copy my contacts to pc or another phone
You can copy the contacts to the PC easily....But to other phones it tough since you don't have the display.
Contacts to PC:
You should first have Nokia PC-suite for it.
If you don't have, download the PC-suite from here
http://europe.nokia.com/support/download-software/pc-suites/compatibility-and-download
Now connect the Phone with nokia PC-suite using the USB cable.
Since you don't have the display.Press OK (because internally the phone asks for the PC-suite connection)You need to say ok for it.
You can see two options in Nokia PC-suite.
1)Content copier:
2)Nokia PC sync:
using thes two methods you can copy the contacts now:
Content copier: Click on it and follow the screen step by step and save the contacts in PC
Nokia PC sync: Sync the contacts with outlook.Follow the screen accordingly and save the contacts in excel sheet.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Cell Phones
How do I bluetooth pair my i9 phone with my Ford SYNC
On your Ford Sync board, press the phone button. It will start to search for already paired devices. If none is found, press the arrow buttons until you find 'Add Bluetooth Device'. Then, press OK. You'll see it will generante a PIN. Now, make your phone's bluetooth application look for new devices. After a while, the Ford Sync device will appear on the phone screen. Select it, and make the the bluetooth application proceed. When a PIN (or pairing code, or passkey) is requested, enter the PIN generated by the Ford Sync device.
Hope it works for you.
Regards, Carlos
May 20, 2010 | Cell Phones
Calendar Sync issues with Treo 650
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
Sep 11, 2005 | Palm Treo 650 Handheld
Fitbit Charge Wireless Activity Tracker Sleep Wristband Large Logo
121 people viewed this question
Top Fitbit Exercise & Fitness Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
