The PC won't start, won't even reach the boot up stage. Keeps tripping and trying to power back on.
When switching it on, the fan starts and it sounds like the HD wants to kick in, but then suddenly it all "trips", with the fan switching off and a beep noise with it. The pc automatically tries to start again, and the same cycle continues. I have unplugged it and left it unplugged for a few minutes with same results. Have also disconnected any unnecessary extras (printer, speakers). Could you please help?
Neal Schwartz
    Habit-Forming:
    New Friend:
  • 24 Answers
You need anew power suply
Posted on Mar 09, 2016
Coco the Bean
    Dedicated:
    Visited the website for 20 consecutive days.
  • 457 Answers
Open it up and turn it on and see if the power supply fan stays on if not replace it.
If it was a bad memory chip the beeping wouldn't stop.
Posted on Feb 29, 2016
5 Related Answers
sandrew
andrew pester
  • 2961 Answers
SOURCE: At Start up, beeps several times, won't boot.
This could be an overheating processor problem,dependant on the motherboard and what the beeps mean. The fan speeds up to cool it down, there may be dust collected in the heatsink on top of the processor, check it and gently brush off dust. Check that the vents on the side are atleast 6 inches clear of anything for good circulation. To see if it is an overheating thing, remove both sides of pc and run it in an open space to see if the same thing happens. While you have the side off just check your memory and other peripheral cards are all seated correctly and not loose.
Posted on Jan 22, 2007
fwadley
Farren Wadley
  • 482 Answers
SOURCE: PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Posted on Dec 23, 2007
XXXX
  • 39 Answers
SOURCE: No image input and pc makes weird sounds on start up
Remove & reinstall all the memory sticks (reseat). If that did not fix the problem, remove all the memory sticks and reinstall them one at a time to test them in an effort to determine if one of them has gone bad. Use this same methodology to test all of your device cards.
Check to make sure the CPU fan wire is connected to the fan header on the motherboard and that the fan is operational. Most motherboards (especially AMD) require the CPU fan to be operational and connected to the motherboard to avoid frying the CPU. However, this requirement can be disabled in the bios to accomodate CPU fans that do not run off of the motherboard fan header.
Can you get into the bios? If so, I would suspect the CPU and memory are ok. Does the clock have the right time? If the time on the clock is wrong it could indicate your bios settings are not being maintained after you power down and you may need a new CMOS battery.
Usually a beeping motherboard is an indication of a hardware issue. The data on your hard drive is probably intact. If you need to retrieve some files from the drive for your graduation, you can always install the hard drive into a USB external hard drive enclosure and connect it to an oprational computer.
Hope this helps - good luck!
Posted on Nov 01, 2008
Anonymous
SOURCE: ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Posted on Nov 20, 2008
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: Compaq: CPU fan has failed PC will automatically power down
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through fixYa.
Thank you
Posted on Nov 27, 2009
IROG-1 at start up keeps repeating how to fix
Not sure what you mean, but I assume that you mean that your computer starts to boot but never completes the boot process into Windows, it just freezes. Am I correct?
Jul 03, 2014 | Asu ROG Rampage IV Extreme Desktop...
Won't build top pressure an shut off
It sounds like your pressure switch is not set correctly. It is possible it is set too high for the compressor you have.
Sep 23, 2017 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
Amana AC model MBR2000, installed mid May 2009. When outside temp gets above a certain level the AC does not cool. fan keeps running and it keeps trying but not work. When outside air gets cooler then...
Hi it sounds to me like what actvates the 2nd stage of the compressor is not turning the compressor on when the ambeint temiture reaches the point that it calls for the 2nd stage to start it may be an out door thermostat or a ambient senser and I would request a new Tec to come out and ckeck
Aug 24, 2009 | Heating & Cooling
IGBT FAULT ERROR KEEPS OCURING ON DF6 340 IVERTOR INVERTOR HAS RUN 14 INTAKE FANS FOR ABOUT 4 YEARS NO OVERLOADS ARE TRIPPING ETC
E30 IGBT fault If an excessive current is applied at an IGBT (transistor in the power end stage), the output voltage
is switched off to protect the transistor.
Sounds like maybe a fan has gone bad and is drawing too much current.
Try disconnecting the fans and reconnecting one at a time. Also check
the fans to make sure they turn free and are not blocked.
Aug 17, 2009 | Electronics - Others
P4/not booting up upon start
Hi try to open you chase and unistall all the additional slot cards and try to boot up, sometimes one of the slot cards fails and if that happens your machine wont start up until that slot cart is removed, thats how your machine protects it self
May 08, 2009 | Intel D865GBF Motherboard
Itronix VR-1 Go Book Fan Failure message
After bios upgrade had same problem. DISCONNECT AC POWER PULLED BATTERY FOR AT LEAST 5 MINUTES THEN REATTACHED BATTERY AND FAN WORKED ON NEXT RESTART. Also make sure boot menu ( tap F12 at start-up) is set to boot from Hard Drive. I also started on battery power with no ac adapter.
Apr 17, 2009 | Computers & Internet
Wont boot
Check all connections. If you connect your pc to the mains supply and the fans run straight awayeven before turning on the computer switch ( and no beeps, no video). Well this could indicate a dead CPU. I have experienced this on 2 systems. I replaced the CPU and the motherboard and ram were OK .The CPU was totally dead and ended up in the bin!
Jun 27, 2008 | Intel Motherboard
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
Computers & Internet Logo
112 people viewed this question
Ekse
Marvin
Marvin
