Question about Mercedes C-Class Exterior Pillar Posts Trim Set
I turn car on cranks fine no throttle /acceleration gas pedal goes to floor no response in park drive neutral or reverse . ESP sensor is on I have tried to push button and disconnect battery.
Posted by albert redeaux on
Renee Knafel-Bullock
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 355 Answers
Whatever you do dont push the pedal to th floor on fuel injected motors, you will do nothing but harm to your vehicle very dangerous as each time you mash pedal to floor gas will dump in the intake, and lay at the bottom and not burn time and time again till one time you blow out your intake, never push the pedal down and turn key on fuel injection, crbed motors are different than injected motors, hope this helps.
Posted on Jun 04, 2016
I was told my linkage cable between the steering column and transmission might be the reason my van won't accelerate
linkage cable only changes ratio selections
if it is faulty , it will be stuck in one gear
the reason it is not accelerating is because the accelerator pedal and the throttle control are not communicating with each other
run the fault codes to check which sensor is faulty or if any other sensor is responsible
Feb 13, 2017 | Cars & Trucks
Gas pedal wont go down once in gear
I would check a few things. first the engine mounts. make sure the engine isn't rocking over. second cruise control ? if it has cruise control I would unhook the cable to the throttle from the cruise control and see if that was the issue. some times the control box will pull in deceleration mode and stick there. also the decelerator valve on the throttle body may be defective.
May 24, 2013 | 1998 Dodge Neon
01 Nissan Frontier XE 4x4 Acceleration problem
Have you had the TPS calibrated? it needs to be set at a position with a specific resistance to set the correct idle speed, There is also no point try to do anything while you have the vacuum leaks as this make tuning impossible.
Mar 06, 2012 | 2001 Nissan Frontier Crew Cab
I have p0700 and p0705 codes, p0455, p1125, and p2125 and p2138 codes
P0700
The transmission of a vehicle which has suffered a transmission problem will send the P0700 code to the vehicle engine control module (ECM)
P0705 Transmission Range Sensor Circuit Malfunction
Possible causes
- Open or short park/neutral position switch circuit
- Poor park/neutral position switch circuit connection
- Misadjusted park/neutral position switch
- Park/neutral position switch may be faulty
P0455. A code p0455 most likely means one or more of the following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
Other leak or damaged piece in EVAP system
P1125 Accelerator Pedal Position (APP) System
P2125 Throttle/Pedal Position Sensor/Switch "E" Circuit
P2138 Throttle possition sensor
Jun 23, 2011 | Chevrolet Equinox Cars & Trucks
I have a 2000 GMC Jimmy that has around 93,000 miles on it. The last oil change was 2 weeks ago. Today, on a trip on the interstate, I pulled off to have dinner. When I left the restaurant and started...
If the trucks engine rev'd up when you first put the gas pedal down, but didn't go anywhere then it was probably in neutral (not drive as you thought). If it was in drive and still didn't go anywhere but engine still rev'd up then its a transmission issue or PRNDL switch at the side of the tranny. I can't see anything relating to the gas pedal by NOT reving up the engine when it was pressed down. I wouldn't suspect a throttle cable issue. Check the tranny fluid while truck is running in park, see if the fluid is badly burnt or low on the dipstick. If it looks good I would have the PRNDL switch checked. (Park Reverse Neutral Drive and Low) switch.
Jan 31, 2011 | 2000 GMC Jimmy
2002 Camry won't accelerate
check throttle position sensor wire chewed up, broken wire or unplugged? check with volt meter mesure the voltage @ throttle positon sensor see if there's voltage goes up/down when u apply/release gas.
Mar 13, 2009 | 2002 Toyota Camry
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
50 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
