Mercury Marine 15hp & 20hp 4 Stroke Outboards Outboard, 115lb., 15" Logo
g
gwynne kuhse Posted on Feb 28, 2016
Gas flowing out of the top of carb. this is a 9.9 mercury 4 stroke outboard motor.
Hammerite
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Mar 11, 2016
Hammerite
Contributor
Level 1:
New Friend:
Answers
26
Questions
Helped
7235
Points
52
this can happen when the float in the float chamber of the carb. jams or "grot" gets in the way of the seal that pressure from the float should create to stop fuel entering the carb. An easy fix, if this is the cause. Unscrew the float chamber be, careful of the gasket, and clean inside, check float for freedom of movement. I prefer paper/fibre gaskets. Good to keep a spare in your kit.
Hope the above was of help.
  • gwynne kuhse
    gwynne kuhse Mar 12, 2016
    thanks for the help, I had to replace the float. Works fine now
I have a Mercury outboard 4 stroke 4hp and gas is leaking from vent tubes on top of carb. Why is this happening and the best way to repair this problem
Carb is probably flooding due to a stuck float, dirt trapped in the float valve or the float valve is damaged or worn.
Only taking it apart and checking will find the reason though a stuck float can sometimes be freed by tapping the carb with something like a plastic screwdriver handle.
1helpful
Lots of gas in my 2002 90 horse fourstroke Yamaha.
No Jason.. relax.. I do need more info.. where is the gas? If its accumulated in the bottom of the shroud.. you probably have non-sealing needle and seats..if its filled the crankcase = the same issue. take it to a competent professional and have them clean and set the carbs.. and check the needle/seat assembly in all the carbs. They are what regulates the flow of gas into the carbs... when they do not close... the gas has to go somewhere.. and its never good...
1helpful
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 • Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Top Mercury Marine Boating Experts
vince
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Mercury Marine Boating Expert? Answer questions, earn points and help others
