Question about Stihl Garden
I Need the service and repair manual for for a Stihl MS240/MS250/MS260C Chainsaw. It's the same manual for Stihl MS260,yes?
Posted by allentenderf on
L Pfaff
    Top Expert:
  • Stihl Master
  • 11,573 Answers
  • 1 more comment
  • L Pfaff
    L Pfaff Feb 28, 2016
    Allen, your welcome, happy cutting and be safe.
  • allentenderf
    allentenderf Feb 28, 2016
    The first link does not connect
  • L Pfaff
    Try copy and paste it on the google search box.
Plink-plonk
  • Stihl Master
  • 1,807 Answers
How to replace pullcord on chainsaw
Hello, here is website to help you with replacement.
Pull Cord Repair On Stihl MS250 Chainsaw
Nov 14, 2015 | Stihl Garden
I have a ms260 pro stihl and need piston and rings for it, is the parts different or same as the ms260?
if it is the same cc rating , the parts will be the same , regardless of what the other motor is in if it is a stihl ( hedger trimmer ,chainsaw etc
you have stated the same motor model so it is difficult to guess what the other motor is
Oct 30, 2015 | nwp Piston Rings For Stihl Chainsaw 026...
Need repair and service manual for Stihl 012 chain saw engine
google the stihl web site and if there are manuals available ,you will find them there.
May 27, 2015 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Stihl schematics
The gasket goes between the carurator and the engine.
Jul 27, 2014 | Stihl 024 026 Ms240 Ms260 Throttle Trigger
Stihl ms250 service manual
http://stihlusa.com/information/info_product2.html
May 11, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Installing a spring in an MS240 Stihl chain saw
I have not worked on you type saw. I have put new starter springs in other saws. One end of the spring fits into the housing and the other in the pulley. Once you have that done there should be a notch in the pulley that you put the rope into that will allow the spring to be wound up without taking up the rope. It is a trial error problem now. If the spring is wound too tight you will not get full rope travel. If it is too loose tilt will not pull the rope in fully.
Jun 01, 2013 | nwp Starter Recoil Spring Fits Stihl 024...
On a Stihl MS250 Chainsaw are both bar hold down studs into the plastic tank if the front one is stripped can it be fixed
Hi, yes and yes. You can buy an oversize stud from a stihl dealer that is designed to fix your problem, regards Phil.
Sep 01, 2012 | Amana Garden
Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
Top Stihl Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
bryan st
Are you a Stihl Garden Expert? Answer questions, earn points and help others
