Washing Machines Logo
Question about Electrolux Washing Machines
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
Posted by quoc su Pham on
Dado
    Master:
  • Electrolux Master
  • 511 Answers
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Posted on Mar 02, 2016
1 Related Answer
Anonymous
  • 8 Answers
SOURCE: E9F code
Wonderful.
Share a website with you ,
( http://www.wholesalemkt.net/ )
Believe you will love it.
We accept any form of payment.
Posted on Oct 15, 2012
Electrolux washer model EWFLW65F error code e9f - Parts Replaced
Sounds like you did great job of following the service manual and advice for parts suppliers, but often, it is service tech knowledge that is useful. For instance they will look at a board and say "yes, this board fits most of them, but not yours", or they say "these boards are made on Taiwan for 5 bucks each and 8/10 don't work, I keep 20 in the van". also these days, techs carry a laptop computer and connect to a Service Port, like the OBD2 port on a car. The machine tells them the issue.
Your choice, Service Call or Shiny New Machine. You can't do any more than you have done.
you have obviously seen this, but did you check the connection to the Inverter board on the motor and the soldered joints behind the connection? Different model, same code.
E9F: Communication Error Between Main Board And Inverter ...
https://www.manualslib.com > ... > Service manual
Electrolux EWM25 series Manual Online: E9F: Communication Error Between Main Board And Inverter Board. E9F Checks to perform: Measure the continuity between ...
Code e9f on my electrolux front load washing machine
Exactly.
You can only check the connectors between main electronics and user interface. Sometimes due to vibration the connectors lose a good connection, otherwise main board(PCB) or user interface (PCB) is faulty. It is difficult to find out which of them is incorrect.
Only authorized service providers have a interface for connecting to the electronics of the washing machine.
Dado
I am after a picture of the motor wiring on an ewf1282 front load Electrolux washing machine. There is a spare yellow wire which comes from the ECU, but the only place it looks like it will attach to
Good Morning Friend,
I understand that you are looking for a picture of the motor wiring for your Electrolux washer, model# EWF1282. This appears to be an Australian Electrolux dishwasher. I suggest contacting the manufacturer directly. They might be able to get you a picture of the motor wiring. Hope this is helpful.
-Best Regards-
WP
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
1helpful
Electrolux washer playing up!
Remove the top panel, there should only be 2 or 3 screws on the back of the panel, then slide the top panel back about 1/4 inch and it should lift off. Look to see if the belt has come off. Post your results back.
2answers
E9F code
Communication problem. Check the wiring between the Main Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board. Here is the part you need.
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
2helpful
I have a electrolux ewf1282 washing machine with a error code EH1 can you tell me what this is
Incorrect mains frequency-The power supply frequency is not within the configured limits.
Have a load of washing in my front loader and now my LG wasing machine says 'UE'. What does this mean and how do I fix it?
is this an Lg washer ie error code is an water inlet error machine notices low water pressure , you either have kinked fill hoses , plugged screens in fill hoses coming to you watervalves or watervalve is damaged from foreing debris coming into watervalve .........
Electrolux front end loader
How Old is the machine: Is it within the 5 year major parts cover? If so the drum bearings are covered.
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
