The controller works because it has a many light that works.But when you move the controls it doesn't do nothing but stay there I tryed to charge it but it didn't do nothing at all.Please help me quick.
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires.
2.turn off your heli and insert charging socket into your heli's socket.
3.the charging green light will light up while charging.
4.charging complete, the green light will turn off.
5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
SOURCE: hi my helicopter is 9053 , my helicopter working
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
SOURCE: when i turn on the remote control, the red on/off
The batteries in the controller are nearly flat
SOURCE: right out of the box
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
SOURCE: My new u-control helicopter is experencing spinning
I had the same problem, the helicopter would spin out of control and the trim did not help. I took a closer look and noticed that only the top rotor was turning. I took the bottom off of the round gear box to find a tiny white gear had slipped off the second motor. With a pair of needle nose tweezers I was able to reattach the gear and I was flying in no time.
For one thing, there are only two channels. Although the transmitter shows a,b,c the switch has only two positions. The way to assign a channel to a heli is to turn it on and then simply operate the transmitter. The heli will lock itself onto the first frequency it receives, and start working. Before turning on the second heli, make the first transmitter is OFF, and set the second transmitter to the other channel. Turn on the second heli and simply operate the transmitter. The heli will lock itself onto the second transmitter's frequency, and start working. Then you can turn the first transmitter back on.
