Question about Tamron Cameras
My tamron lens 18-270mm pzd is flickering and having difficulty in focusing. Where can I get it fixed.
Posted by Nasir Azeem on
james laughton
  • Tamron Master
  • 2,195 Answers
Go to the tamron site and find the nearest repair centre to you location
Posted on Oct 29, 2016
5 Related Answers
Anonymous
  • 667 Answers
SOURCE: tamron 28-300mm lens disassembly help
Both, But start at the rear to remove the electronics and the outer barrels. Remove any rubber grip to expose 'hidden screws'. I would mark everything or document with pictures during disassembly.
Posted on Jan 29, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Tamron 90mm 2.5 adaptall man focus lens
You probably have to set the aperture manually on the lens, because it might not have CPU contacts. I think changing the aperture on the camera will probably have no effect, so just try twisting the aperture ring to wide open.
You usually have to set the aperture at the minimum setting (highest number) so that if the camera is choosing the aperture, it can stop down to the required value.
No good having it set at f2.8 if the shot needs f11.
If the lens is very old, it might have a manual iris that you have to set yourself on the lens. The lenses that stop down automatically will have a tiny peg on the mount that a suitable camera can operate. Gentle pushing of this peg while looking through the lens will tell if it is stopping down - set it wide open first.
If you have a depth of field preview button, this will also have the same effect with the lens on the camera if the body matches up with the lens.
Posted on Jan 17, 2009
Anonymous
  • 3006 Answers
SOURCE: Have a two month old 18-270 Tamron lens. Used it a
If it's only two months old then it's still under the manufacturer's warranty so send it back to Tamron. I can't tell you where to send it as you haven't said which country you're in. Tamron value their reputation and usually provide excellent after-sales care.
If you're in the UK you additionally have Sale of Goods Act protection for up to six years in England and Wales and five years in Scotland. Either way, the Act allows you to demand a full refund or replacement from the retailer; I'd suggest a refund as bad lenses often come in batches and a different supplier is less likely to have one from the same production batch.
Note that any attempt to fix the lens other than by normal use of the lens and camera controls may completely remove your warranty benefits or consumer protection.
Posted on Oct 28, 2009
Anonymous
  • 3006 Answers
SOURCE: Cannot figure out how to take good macro shot with new Tamron len
With an SLR you only get true macro focussing on a lens that has proper macro focussing abilities. Unfortunately in the photogaraphy world, there are a huge number of lenses which claim to have macro ability but are stretching the term far too much.
Strictly speaking, macro means that the lens is capable of producing images on the sensor which are the same size as the actual subject or even bigger, at life size this is described as 1:1 macro. Your Tamron lens is only capable of a maximum 1:3.7 "macro", and that's only at the 200mm zoom setting with the subject no closer than 45cm from the lens. By SLR zoom lens standards, that's actually pretty good, but if you want to go closer and get greater magnification you need to either use a supplementary close-up filter lens or for better optical quality use a set of extension rings. The trade off with close up filter lenses is poor image quality and usually plenty of colour fringing and with extension rings is that if you're using a 2x magnification at 200mm, your f5-ish maximum aperture at 200mm becomes a very dark f10.
The only way to get good macro results is to either use a proper (=expensive) macro lens and excellent lighting, or use extension rings plus a good ring flash unit. However you can improve your macro by investing in a more capable zoom lens with a closer minimum focus distance and a better aperture at the telephoto end of the range. This can be expensive, or you can pick up some very cheap 35mm film SLR lenses. Using an adapter will never allow you to achieve infinity focus on a Canon digital SLR but you can get a close focussing 200mm f3.8 very cheaply. The crop factor of your smaller sensor means it will have the same angle of view as a 310mm lens but the aperture will remain at f3.8. As Canon digital SLR's have the deepest body register (lens to sensor distance) of the current systems then you'll also have the effect of using it on an extension ring. The downside is that you'll have to use the lens in a totally manual mode as no information will be communicated to your camera body. By mounting the lens back to front using a reversing ring you can achieve some really stunning macro magnifications but then you need a tripod, powerful flash and absolutely no wind... There was also a Makinon 80-200mm zoom which sells for next to nothing on auction websites, but it had a macro collar which allowed it to achieve around half size macro (1:2).
Alternatively, if the Fuji still works and does the job just keep it in your camera bag ready for those types of shots. overall, that seems the easiest and best solution unless you really want to get heavily into macro shooting.
I hope that I've helped you, please ask more if there's anything unclear. I've tried to keep a very complicated subject as simple as possible. Please also take a moment to rate my answer.
Posted on Mar 05, 2010
Anonymous
  • 10865 Answers
SOURCE: Hi I have a Tamron 28-300 f3.5 AF Aspherical LD
Hello. Yes it can be repaired. Take it into your local Nikon shop for a free estimate, it is often the case that all these lenses need is an internal cleaning and lube and then they are good to go again.
Joe
4 thumbs up please. ty
Posted on Oct 21, 2010
I cannot manually focus my Tamron 79-200mm 1:2.8 lens
First, I'm not a TAMRON Tech.
* Check your warranty and call for service.
* Ah, Found this on you tube. (VERY Technical!)
https://www.youtube.com/watch?v=o9dvQmVAhK0
* Strongly suggest you have this lens serviced.
Aloha, ukeboy57
Jul 02, 2018 | Tamron Cameras
Was I sold a 'pup'? Tamron lens box says AF55-200mmF4-5.6LD MACRO. Can't find macro setting on lens or instructions. Looking at your site, Product Details says 'No Macro'. So what's...
Excerpted from a www.photo.net review of the lens:
Though the Tamron AF 55-200mm Di II LD Macro has "Macro" in its name, it's not really a macro lens. Maximum magnification is about 1/3 life size (Tamron spec it at 1:3.5) as you can see from the following image below, which was shot at 200mm and at the closest focus distance (0.9m/37.4"). This isn't too bad, but it's more of a close focus telephoto lens than a "macro" lens (bolding for emphasis added).
Sep 09, 2011 | Tamron 55-200mm f/4-5.6 Di-II LD for Canon...
What is the focal length multiplier for the Tamron 18-270 mm Di-II PZD VC lens on a Canon XSi digital camera?
It's not the lens but the camera that determines the focal length multiplier. On some cameras the 18-270mm lens is an 18-270mm. The XSi's imaging sensor applies a 1.6x multiplier on any lens used with the camera, so the 18-270mm will be approximately 29-430mm.
Mar 05, 2011 | Cameras
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
Aug 08, 2010 | Tamron 55-200mm f/4-5.6 Zoom Lens for...
Tamron Macro 90mm lens r07 error on Nikon D70S - any ideas how to fix?
Having gone over threee months without a response, I assume this is no longer a problem.
Apr 11, 2010 | Tamron Macro 90mm f/2.5 Manual Focus...
Oct 26, 2009 | Cameras
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Auto focus problem
My first suggestion is to send it back if it is under warranty.
The grease probably got so thick, from the cold, that it caused too much resistance for the auto-focusing mechanism. You probably have damaged the focusing mechanism in the lens. You cannot repair this, yourself. I don't know how cold is too cold but it really shouldn't have done that.... Tamron makes cheap lenses. Try and exchange it for at least a Sigma.
Dec 24, 2007 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
Top Tamron Cameras Experts
Steven Wander
Steven Wander
Harrie
Are you a Tamron Camera Expert? Answer questions, earn points and help others
