Question about Sansui 32" TV
Power outages happen and tv will not come back on. Before have waited days and it will finally turn on.
Have tried holding down on botton on remote and on the backside. nothing
Posted by Marilyn Kruse on
    Top Expert:
  • Sansui Master
  • 76,396 Answers
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Feb 27, 2016
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
Need a code for a RCA Universal Remote on a Broksonic Flat Panel TV
If you have the code book just hold the device you want to set up
like tv, vcdr, etc. and the power button at the same time. The power botton will stay lit. Put in your 5 digit code...hold it till the tv,vcr turns
off. Turn it back on and try the rest of the functions. If it dose not work
on certain function just hold down that key till that function works. Hope this helps.
Sep 24, 2012 | Broksonic Televison & Video
No Video or Sound after power outage
While it's certainly possible to fry the whole power supply or the DMD board, it's more likely that you've blown a capacitor. This same situation happened to my brother's TV after a power outage. I told him to unplug it for a half hour and that didn't help. He left it unplugged and when I finally got around to open it up the following week, I turned it on and worked. (I told him I fixed it).
Unfortunately the same thing happened after the next power outage so I opened it up and replaced two leaking capacitors by the power cord. It has yet to fail again after numerous power outages.
So first thing to try is leaving it unplugged for a few hours or even a day. Keep your fingers crossed that it doesn't happen again. If it does, either you or someone else should open it up and check for leaking or blown capacitors.
Jul 24, 2012 | Samsung HL61A650C Television
Had my toshiba regza 42rv530u since March 2009 a few days ago it cut off and will not come back on, the yellow light flashes at the bottom of the tv, 3 blinks pause 3 blinks etc....
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
May 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Can not find code for my direct tv r32 remote for my 42" ilo
i work for directv hold down the select button and the mute botton while in tv mode then push 991 wait for light to blink then 1 light will blink power button then channel up till your tv turns off
Sep 15, 2009 | Televison & Video
TV wont turn on with power button or remote
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
Jul 04, 2009 | ViewSonic N3735W 37 in. LCD TV
Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Dec 27, 2008 | Sony KV-32XBR85 TV
Remote
the intruction are at the back of the battery .
1 turn on tv
2 press and hold Code Search untill all device bottons light( they will all turn green)
3 press tv button. tv botton will stay on
4 press power repeatedly untill tv turns off
5 press enter and you are all set
repeat 1-5 for vcr , ect
Apr 01, 2008 | RCA RCR350 Remote Control
Sansui 32" TV Logo
54 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
