Question about HP Pavilion Computers & Internet
Hard disk drive - Pavilion HP Computers & Internet
Posted by hussain salih on
Larry Ng
  • HP Master
  • 6,445 Answers
NO use SSD
Posted on Jan 14, 2022
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 • Computers & Internet
tip
NO BOOTABLE DEVICE
When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message - "No bootable device. Insert boot disk and press any key"
on Oct 02, 2010 • Computers & Internet
1helpful
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Need to remove hard drive
his document provides instructions for the removal and replacement of the hard drive for the R3000, R3100, R3200, R3300, ZV5000 and ZV5200 series notebook PCs.
Use the video as a guide while following the written instructions below.
To view the video press the Play button on the player control bar below the video.
To stop the video press the Pause button on the player control bar below the video.
To restart the video press the Rewind button on the player control bar below the video.
NOTE:Flash Player from Macromedia is required to view this video. Visit the Macromedia website (in English) to download and install Flash Player.
Step 1 - Remove the battery
Slide and hold the battery release latch to the unlock position.
Use your finger to lift the battery up and out.
Step 2 - Remove the hard disk drive
Remove the two Phillips-head screws that secure the hard disk drive to the base enclosure.
Lift the inside edge of the hard disk drive to unseat the hard disk drive connector from the system board.
Remove the four Phillips-head screws that secure the hard disk drive to the hard disk drive bracket.
Remove the hard disk drive from the hard disk drive bracket.
Pull the hard disk drive out of the bay.
Place the hard disk drive in a static dissipative bag.
My laptop cannot read my hard disk, why?
Either:
* no power reaching the hard-disk
* the "data" cable is no longer connected to the hard-disk and/or to the motherboard
* the "spinning" part of the hard-disk is no longer spinning
* the "electronics" part of the hard-disk has failed.
Take the computer to a qualified computer technician, for trouble-shooting, and possibly a replacement of the disk-drive.
Is the disk-drive still under warranty? If so, exercise the warranty to get a replacement disk-drive.
1helpful
2answers
I want to replace HDD on my HP ProBook 4510sand I don't know how help somone.
Hard Disk Drive removal
  1. Review the safety considerations before performing the steps listed below by clicking on the following link: CAUTION: Failure to comply with the precautions could result in damage to your product or loss of data. CAUTION: Observe all precautions when removing and replacing components.
  2. Remove the battery, switch cover, keyboard, and palm rest.
  3. Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
  4. Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  6. Remove the hard disk drive from the hard disk drive bay.
  7. Place the hard disk drive in an electrostatic dissipating bag.
Hard Disk Drive replacement
  1. 1. Remove the hard disk drive from the electrostatic dissipating bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the system board connector.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Server XSeries 220
Yes, that is the total amount of hard drive space.
This server was built for speed not for storage.
The xSeries 220 server supports four SCSI hard disk drives. The server does not support IDE hard disk drives. Some models support hot-swap hard disk drives and other models support only non-hot-swap hard disk
drives.
Your server supports four 1-inch (26 mm) slim, 3.5-inch SCSI hard disk drives in the hard disk drive bays. You can install four non-hot-swap hard
disk drives in the models that have the standard non-hot-swap drive cage. You can install three hot-swap hard disk drives and one on-hot-swap hard disk drive in the models that come with the hot-swap drive cage. Both the non-hot-swap and hot-swap drive cages hold a maximum of three hard disk drives.
The calculation at that time was 4 drives with 36.7GB storage.
Even if you find the drives somewhere, they will be very pricy.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
I have 3 Hard Disk Drives and my C one is full and the other two are not how do i mack them all one Hard Disk Drives?
"mack them all one Hard Disk Drive"? do you mean make them into one Hard disk drive?
if you have 3 "physical" Hard Disk Drives, im sorry but thats not possible
but if the 3 Hard Disk Drives are only partitioned you could use any partition manager software like Partition Magic or Acronis Disc Director suite to combine the 3 Hard disk partition into one...
hope this helps
^_^
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Mehandi Husain ...
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
