Dishwashers Logo
L
Lenore Levine Posted on Feb 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The CHILD LOCK light came on and I cant get it off. Pressing CANCEL does nothing. How do I fix it?
Level 3:
  • KitchenAid Master 6,688 Answers
  • Posted on Feb 26, 2016
Cindy  Wells
KitchenAid Master
Level 3:
Answers
6688
Questions
0
Helped
3529964
Points
21744
Usually you need to press and hold a button or a pair of buttons to toggle the Child Lock function. Without the model number of your dishwasher, I can't be sure if this will work on your machine. It did work on the old Kitchenaid I had. Press and hold the Energy Saver/Dry button for 4+ seconds. If the light goes out, you have released the front panel lock.
On some models, you needed to press and hold the Air Dry button. However, you may need to look for writing in a small font that will indicate the correct button/key combination to release the front panel lock.
If pressing the appropriate button for an extended time doesn't work, then your keypad may need to be replaced. The signal isn't being received by the control of the dishwasher. (Alternatively, the wiring between the keypad and control unit or control unit, itself, may have an issue.)
I hope this helps.
2answers
How do i get my kenmore dishwasher to change from light wash to any other cycle, its kenmore ultra 13449k900 model, runs fine on light duty
Well, if you can't change the cycle by pressing another cycle button, yet you CAN press Start or Cancel and it responds, then you probably have a bad control console. If nothing responds, then you may just have the control-lock (or child-lock) feature turned on.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Forgot my childproof code now i cant use my microwave how can i get a new one
Many microwave CHILD LOCK features are activated / disabled by repeatedly pressing one of the function buttons or by holding it down for about 5 seconds.
Try pressing the STOP / CANCEL button 3 or 4 times in a row to see if you can the CHILD LOCK off.
If that doesn't work, also try holding down that button down for 5 seconds.
Try these same two procedures on some of the other buttons as well like the TIMER button, or the START button, or the CLOCK button.
Your best bet however would be to include the brand and model number with your question next time and then we will be able to locate the exact instructions for you.
I hope this was helpful.
Good luck and take care.
Joe.
HJA8630, switched on and all program lights and play on cant do nothing
most likely the door switch is faulty or the child lock button is pressed. Press Cancel to see if anything happens Otherwise you have to test why the door is not latching properly.
8helpful
2answers
How do I cancel the child lock on dishlex dishwasher 2005 model
Hi, ours is the 403 model but im guessing it will be the same operation for ur 302 mod, In prog selection mode press and hold start for 5 secs, indicator lights should flash then CL wiil appear to indicate child lock on........ in this mode by pressing and holding any button for 5secs will temporarily give you access to program setting and control an will auto reactivate after 15 secs, ..... too disengage permanently firstly you must temp unlock as above then press and hold start for 5 secs, CL should display with a long beep to indicate CL is off..
Cheers Jeff QLD
12helpful
2answers
How do I unlock the child lock on my Panasonic Genius Microwave?
March 2009 press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
Or, press "Cancel" three times to clear the (child) lock.
You set the lock by pressing "Start" three times.
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
5helpful
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
The Control Locked Light stays on and nothing else works
Is this like a child lock?? if so holding the appropriate button down for upto 10secs is the fix. is the control locked? it not its just the diode circuit which is faulty and will not effect the operation
3answers
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
3answers
Child Lock continuously flashing
the solution is to change the electronic control.....cost 110$
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
