Ideally you should have it replaced, if you hired a fabricator, insist that it be replaced or repaired to your satisfaction. If it cannot be replaced, bring it to a local fabricator and they can glue it back together with epoxy. The crack may become completely invisible or may show quite a bit depending on the color and pattern of the stone. You can also ask a local fabricator if they will give you some epoxy and you can glue it together yourself by pushing it tight and letting the epoxy dry, then scraping off the excess. You will likely still see the crack in this case especially if you don't color match the epoxy.
Send it back
