Question about Lanier Office Equipment & Supplies
What do i do if the control panel is not functioning when you put on the lanier ld115 copier?
When you on the main switch, the machine is quite on but when you press like the button to increase the the quality of the image, it is not acting and when you start copying the screen and the control panel goes off while the machine is still on.
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Dead touch screen
did you try to turn the brightness button.
Posted on Jun 19, 2008
Anonymous
  • 126 Answers
SOURCE: IMAGE TOO DARK ON GEI GRAPHIC ZOOMER POSTER BANNER SYSTEM
First I would give the optical area a good cleaning --- mirrors, lens, etc.. If this device has the 'slide' adjust for the image quality, the slide may have come out of the holder. Try seeming if the slide is seated properly. If this is the 'thumb / circle ' adjust, the POT ( value adjust on the board) may need to be reset. There is always the chance the the board is cracked or has a cold solider joint (pins) for the adjuster. IF you are inclined, that the cover off and check for crack, if no crack heat and re-solider the pins for the adjust switch.
Posted on Jan 04, 2009
Anonymous
  • 41 Answers
SOURCE: I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
Posted on May 22, 2009
quennie732
  • 422 Answers
SOURCE: lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
crystalco43503
Shyam Gaur
SOURCE: copier gets ready, E000530-0000 is coming back again
error code e000530-000 moder ir3300 canon
Posted on Dec 31, 2013
I have LANIER LD115 Copier/ printer can not copy and print ,red light showen on copy button,Erro shown " SC: 544" AND " CALL SERIVCES" , GREEN Light on copy indicator, red on printer light, shown up
The copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
This error can mean the:
PSU board is bad
IOB board is bad
BICU board is bad
Defective thermistor in the fuser
Defective power supply
You need to contact a local service technician to take a look at your copier.
Nov 08, 2014 | Office Equipment & Supplies
How do you set the Lanier LD035 duplex unit?
Metal tab on right side of copier is bent and correctly touching the duplex unit interlock switch. Open the duplexer and notice the metal tab stick out. Put back to a 90 degree angle.
Jul 30, 2014 | Lanier Office Equipment & Supplies
Default password for Lanier LD118d PCL
user is: admin
password is: password
for new model password is empty
Feb 06, 2013 | Lanier LD115 118 118D Toner 9 000 Yield
Copier Canon iR3300 error E000003-0000. How can I reset the copier if the monitor shows the error and it is not otherwise operable. I turned the main switch off and on to no avail. Can anybody help?...
Hi you need to enter in service mode first
in the control panel press the next secuence:
press adittional function
press 2 and 8 at the same time
press again adittional function
service mode should appear in the screen. if don't repeat the procedure until it does
in service mode press
COPIER, then FUNCTION, then CLEAR
select ERR and press ok
turn off the machine from the main switch for about a minute.
restart the machine and try to make some copies, if problem persist there is a malfunction in the fixing unit. get technical support. i hope this can help you
Oct 26, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Feb 17, 2011 | Ricoh Aficio 1035 Copier
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
Hello there i have a lanier copier model ld 160c color copier everthing work fine and functional acceipt i can not make full color copy, when i press the full color button then the display panel show up TO...
Hi, somehow the external key counter option for your copier got turned on. This option is typically used for coin-operated copiers such as those found in libraries. You can turn this option off by doing the following:
- Press the User Tools button - Select System Settings - Select Admin Tools - Select Key Counter Management - Choose Off, or de-select the full-color option if it is selected. - Exit out of User Tools
Now you should be able to copy normally!
Dec 02, 2010 | Lanier UNKNOWN
Ar-160 display says "check panel" no more codes or functionality
tis problem is some of panel button is short i mean it is lock please open your machine panel board and service it . then solve your problem
Aug 02, 2009 | Sharp AR 201 Copier
Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Apr 06, 2009 | Lanier Office Equipment & Supplies
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
